Magic Chef CDB6100 Built-in Dishwasher
Problem for Magic Chef CDB6100 Built-in Dishwasher
Detergent dispenser
By fhinch on Aug 08, 2006
dispenser will not 'close' on detergent, letting both pre-soak and main wash detergent into washer...
Solution #1
posted on Aug 08, 2006
Not Rated)
take
Rank: Wiz
Rating: 79%, 491 votes
well come apptech....
Was this helpful?
Yes
No
Solution #2
Not Rated)
apptech
Rank: Master
Rating: 87%, 33 votes
View breakdown diagrams for your dishwasher model: http://www.appliancepartspros.com/partse... , click on "Rinse aid & soap dispenser" diagram on the left. You may need to replace #6, #4 or #1.
Hope this helps,
APP tech
http://www.AppliancePartsPros.com
Was this helpful?
Yes
No
Solution #3
Not Rated)
catriver
Rank: Guru
Rating: 94%, 3174 votes
The opening of this dispenser is controlled by a wax motor for release. If you are unable to keep the latch shut you are probably looking at the spring and latch assy. This is not a hard job, but you have to open the inner door to get at the latch. Part numbers for the spring disp. flap is 912547. The latch (inside door) is 99001291. If you take your time and observe carefully the job will be easy. Catriver, post back.
Was this helpful?
Yes
No
Popular Solutions for Magic Chef CDB6100 Built-in
Questions and Unsolved Problems for Magic Chef CDB6100 Built-in
Do you recommend Magic Chef CDB6100 Built-in Dishwasher?
Answer
Answer
my dishes are dirty and the glasess have ground up food all over the out side and the bottom that is... (More)
Answer
Did not finish the cycle last night but continued to make the sound as if the pump was still... (More)
Answer
Hello Mr Fixit, When I turn the dishwasher to the normal clean cycle, I can hear it very quietly... (More)
Answer
I had my kitchen drain snaked. When I tried to start the dishwasher, the water entered, but it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Chef CDB6100 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1581
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
