Question about Seagate Medalist Pro 2160 (ST52160N) 2.16 GB Hard Drive
Windows XP Open Folder Problem
In using Windows Explorer to review files and folders, I am no longer able to open a folder in the right window by clicking on it. I get the "open with" window that asks me to choose a program to open it.
I can open a folder in the left window with a click or in the right window by - right clicking to get to the popup window and then clicking on explore.
This began recently after a Windows update. Used to, I could open any folder anywhere with a double click.
Any suggestions for a fix?
  • Mac191919 Oct 29, 2008
    Fixed the problem by replacing the registry with a backup I had made last spring. I recently downloaded a registry cleaning program and apparantly I had cleaned out the registry key that made the folders open. There was no virus found by Trend Micro.,
  • 849 Answers
Your computer is infected with virus, de-infect it,
Posted on Oct 24, 2008
Windows Explorer makes folders that are not needed? How do I delete them when they say write-protected?
Chances are your Windows Explorer is set to show hidden files. Some are write protected because they're crucial to your OS's functionality.
Hope this helps!
Sep 15, 2014 | Microsoft Windows XP Home Edition
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
Cannot create folder
Use Windows Explorer to open the folder in which you wish to create the new folder.
The "My Documents" folder is a good choice if you are new to Windows.
Look at the left side of the Explorer Window for an area marked "File and Folder Tasks."
Click on the link that says "Make a new folder."
Click on "File" on the menu bar to begin creating a new folder in a different way.
Select the "New" menu item and click on the "Folder" submenu item.
Move the mouse cursor to a blank area of the folder area and right click to bring up the context menu to begin creating a new folder in a third way.
Select "New" and click on the "Folder" submenu item.
5
Utilize a fourth method to create a folder directly on the desktop.
Right click on a blank area of the desktop.
6
Type a name for the new folder in the highlighted area after using any of the methods described in Steps 2 through 4.
Press the "Enter" key or click in a blank area of the folder window to complete the process.
also you might just open your drive right click inside select new folder and name it.
Restore Folder Options in Windows XP
Windows XP has several viewing options that you can modify for folders in Windows Explorer. These include being able to customize whether you activate items by clicking them once or twice, whether Windows displays hidden and protected files and several other options.
If you have played with these options in an attempt to determine how you prefer to use your computer, you may accidentally reach the point where you have changed so many items that you are unsure of how to revert to the original configuration.
For this reason, Windows XP allows you to restore the folder options to their defaults by clicking a button.
Open Windows Explorer.
Two of the fastest ways to do this are by clicking the "Start" button and then clicking "My Computer" and by double clicking the "My Computer" icon on the desktop.
Click the "Tools" drop-down menu and select "Folder Options."
Click the "General" tab, and then click the "Restore Defaults" button if you would like to restore the default settings for the "Common Tasks" bar on the left side of folders, whether new folders open in the same window or a new window and whether items open with a single click or double click.
Click the "View" tab, and then click the "Restore Defaults" button if you would like to restore any advanced view settings to their defaults, such as whether Windows displays hidden and protected files.
Click the "Reset All Folders" button if you would like to restore the default viewing option to all folders, such as the detailed view or list view.
Click "OK" to save your changes.
http://support.microsoft.com/kb/812003
Aug 14, 2013 | Western Digital Passport Computers &...
My taskbar icon for volume is no longer there. How do I get it back? I have gone into control panel but I cannot get the sound. I reall
Please follow the steps mentioned below:
1) Control Panel and open Folder Options. 2) Under the View tab uncheck "Hide protected operating system files (recommended)". 3) Now go into Windows Explorer(Not Internet Explorer) and go to C:\Windows\System32\dllcache folder and open it. 4) Locate the sndvol32.exe file right click it,choose copy. 5) Next go to the C:\Windows\System32 folder and open it. 6) In the right pane right click an empty area and choose Paste. Now you should have your volume icon back.
Hope this helps.
Jul 08, 2010 | HP Pavilion dv2000t Notebook
Lost my Outlook Express. exe (using Windows XP). How can I download this and can I get all my "saved" folders on my previous account?
Hope you get lucky with this:
Go into your Control Panel and open Folder Options, under the View tab checkmark "Show hidden files and folders" and uncheck "Hide protected operating system files [Recommended]", click Apply/OK. Now go into Windows Explorer and go to C:\Windows\System32\dllcache folder and open it. There should be a copy of msimn.exe there. You can right click it, choose Copy then paste it into the C:\Programs\Outlook Express folder.
if nothing happens then, For futher and any other technical troubleshooting contact, virenderhasanaccount@hotmail.com
Jan 06, 2010 | Microsoft Windows XP Home Edition
Zone Alarm will not start up when I turn on my computer?
You can ADD the "Zone alarm" executable to your windows startup.
This can be done in 1 simple way.
1. Locate the "Zonealarm.exe" in your "Program files" folder. Usually your Program Files folder will be here "C:\Program Files". Just run a search for "Zonealarm.exe" inside this folder.
2. After locating the "Zonealarm.exe" file, right-click on that file. And select "Create Shortcut".
3. After that you'll find a "Zonealarm.exe" Shortcut file or icon inside the same folder.
4. Just COPY or CUT the shortcut file.
5. Now Right click on the "START" button.
6. Select "Open all users".
7. This will open a windows explorer window. Locate "Programs" folder and Enter it.
8. Inside you should locate "Startup" folder and enter it.
9. Once u ar inside the "Startup" folder, paste the already copied "Zonealarm.exe" shortcut file.
10. That's it. Now try re-starting the system.
Thanks
Dec 18, 2008 | Microsoft Windows XP Home Edition
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
Aug 24, 2008 | Computers & Internet
Could not select "show hidden files & folders" in folders option
go to system registry.......click start then run and type regedit then find this key HKEY_ LOCAL_MACHINE software microsoft windows current version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....and create new DWORD key and give the name CheckedValue and enter 1 into value data.......
restart your pc..........
good luck.........
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Jul 30, 2008 | Microsoft Windows XP Professional for PC
How can i install icon pack in my windows xp sp2
Change Folder Icon:
  1. Open Windows Explorer
  2. Right klick your folder of choice
  3. Choose Customize tab in the new window
  4. Choose a new folder image for Windows Explorer’s “thumbnail” and/or “icon” view
  5. Navigate to your new icon/image of choice and choose it
Regards
Balisonu79
Feb 15, 2008 | Microsoft Windows XP Professional With...
Wireless network between vista & xp
Open Windows Explorer, and then locate the drive or folder you want to share. Right-click the drive, and then click Sharing and Security. To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer. To change the name of your folder on the network, type a new name for your folder in the Share name text box. This will not change the name of the folder on your computer. To allow other users to change the files in your shared folder, select the Allow other users to change my files check box.
Oct 06, 2007 | Computers & Internet
Seagate Medalist Pro 2160 (ST52160N) 2.16 GB Hard Drive Logo
88 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
