Question about Lux Hardware & Accessories
Lux timer will not ring
I have a very old Lux kitchen timer that will not ring. The time will click away but when it comes time to ring it just stops.
How can I fix this. I took it apart (just the back screws) and oiled it about 6 months and it was working fine.
Today, it won't work. Any suggestions?
Robertshaw Controls Co.
Lux Time Division
Lebanon, Tennessee
    Top Expert:
  • Lux Master
  • 43,983 Answers
Your very old Lux timer has timed out and needs to be retired.
Posted on Aug 08, 2017
  • 159 Answers
SOURCE: refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Posted on Jul 12, 2007
SOURCE: Oven wont work after cleaning
I have a single wall oven by fisher paykel I have had the same problem with it not working after the last self cleaning mode.
no fault codes show and the fan and light comes on and blows out cold air. I have reset the power and still it wont heat. broiler is out too. I called the store where purchased and was told they will order a part and come out. This must be an ongoing problem as they did not need to come out and trouble shoot .
I will have to barbeque for a while !
Posted on Oct 19, 2007
  • 40 Answers
SOURCE: backlight doesn't come on
if the back light is not coming on then the backlight is eather bad or is not getting power from the circuit board.
Posted on Dec 31, 2008
lenwest
  • 150 Answers
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
SOURCE: My Sunbeam Kitchen Assist doesn't work
Hi there, you might want to check the swithing mechanism that turns the motor ON. I don't think the motor will fail, specially if it doesn't smell like it's burnt.
Just an idea...
Chino
Posted on Apr 07, 2009
I was clean my range and pressed the timer in error and now it will not stop ringing
Usually, if you press the timer button again, it will turn the timer off.
Sep 27, 2014 | Kenmore Elite Sears & Other Brands...
How to set timer
I found a pdf of the manual for your stove. See the link below to download the pdf.
If you press the button that looks like a bell under the clock you can use + an - keys to set the minutes for a reminder timer that won't turn off the oven.
After turning the thermostat to the temp you want and function knob to the setting you want set the cooking time as follows.
You press the button that looks like steam coming off a pan below the clock for 1/2 second .
Then use + an - keys to set the minutes. Every 12 minutes will make a new segment light up on the inside ring so the numbers corospond to hours on the inside ring.
When the time is where you want it, wait 6 to 10 seconds and the cooking and timer will start.
Smeg A42 5 Instruction Manual
Jun 05, 2014 | Smeg A42-5 Dual Fuel (Electric and Gas)...
Low pressure
Hopefully the strainer is just plugged up. Where the water comes out of the faucet there should be a ring that you can unscrew. Underneath that ring is a screen type strainer that gets stopped up. Unscrew the ring, take the strainer off and clean it with water or an old tooth brush.
May 28, 2011 | Delta Faucet 400WF Classic SingleHandle...
How do you remove everything to clean it, the faucet wont swivel left to right anymore
Remove the handle and the retaining ring (nut) and pull the spout up and off you may need to replace the o-rings found there and lube the area with a good plumbers lube, reassemble and you will be good to go.
Mar 03, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
The fucet will no longer move from side to side
Take the handle off and remove the retainer cup remove the the spout clean and lube. If the faucet is very old I would go ahead and get a rebuild kit and do it all at one time.
Feb 06, 2011 | Rohl R3830-APC de Lux Pull Out Kitchen...
Lux 5000 put in new bag but when i turn on the
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Oct 25, 2009 | Electrolux Lux 5500 Canister Vacuum
TIMER IS BUZZING NON STOP.
how old is the oven? does it have a analog clock? If it does then turn the stop time clock and the buzzing should stop.
Oct 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
There is a clicking noise coming from the timer box.
Hello jhansbro,
Welcome to fixya,
You said, There is a clicking noise coming from the timer box.
What is the Model of your Jenn-air range and how old is it.
When did this start to happen?
Waiting patiently for your reply.
Huuum
Oct 06, 2008 | Jenn-Air Kitchen Ranges
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
Hardware & Accessories Logo
420 people viewed this question
Top Lux Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Lux Hardware and Accessory Expert? Answer questions, earn points and help others
