Question about De Dietrich Ovens
Hi, my oven is the DOP740X and functions work fine apart from one setting which is the ciculating heat mode at 180#, the fan works but does not heat at all any idea up at all
  • 1462 Answers
SOURCE: Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
Posted on May 06, 2007
SOURCE: oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Posted on Feb 06, 2008
  • 49 Answers
SOURCE: Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Posted on Mar 05, 2008
  • 1462 Answers
for king louie
fault is the circular element round the fan. take off the back plate inside the oven and you can often see the damage but not always. to get at the terminals, remove the rear cover and test for continuity across the element with a multimeter - remove any connections before doing this and note down where they go
for tarzantony.
i can't remember where the cutout is but probably on top of the oven or close to the fan on bthe back. just trace the wiring from the element and it should lead you to it
Posted on Jul 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
    The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
    Col. Dana Gillespie
    May 11, 2014 | Ovens
    We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
    Hi Maurice.
    Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
    Here an extract from manual.
    There is no preheat unless you set temperature. That is why you get the fan from start.
    Oct 20, 2011 | De Dietrich Ovens
    Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
    whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
    Dec 17, 2009 | Baumatic Ovens
    Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Nov 12, 2008 | AEG D2100-4 Electric Double Oven
    Oven not heating but the fan is working and clock flashing auto
    You need to rest the timer. to get it off auto,otherwise the oven will not work.
    Refer to your instructions.
    Oct 20, 2008 | Neff B1421 Electric Single Oven
    Dear customer,
  • Test the element
    Jul 08, 2008 | Ovens
    Oven no heat
    Jan 16, 2008 | Neff B1641 Single circotherm super...
    Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
    Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
    Sep 18, 2007 | Ovens
    Ovens Logo
    51 people viewed this question
    Top De Dietrich Ovens Experts
    ashburton
    Shehu Pro
    Shehu Pro
    Electro Med Services...
    Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
