A coma computer enthusiast has installed an old ISA sound card in his PC. However, it locks up and doesn?t work when a tape backup unit is used on the system. What is the most likely cause of the problem and how should it be fixed?
2 Suggested Answers
SOURCE: Sound card problem
i have a sound card an i installed but driver s not installed ,an i need the right driver
Posted on Apr 24, 2008
Hp surestore dat 40 scsi tape drive software driver
data tape drive.40
wow a blast form the past.!
im and old SCSI expert, from the old server days, high end.
and tape, wow, a working still tape drive?
why not get it at hp.? join there forum and ask, 1000x better than here, for sure.!!!
omg, hp.com shows, DAT is dead. (expected)
fell off the end of the "BLAST from the PAST" of technology.
like F104 jets./? and Cuba crisis.
i'd love to see it work and make those funky sounds again.
cute.
what good is it, max was 40gb. for data,compressed 20 not.
i'd buy and use. blu-ray DVR
and external e-stat 1TB drives for archival
btw you nee d a matching SCSI card,to make this play
can be had dirt cheap,
I have SCSI 1 CARD (isa) From mid 1980s framed on the wall
for fun.'
next to my framed real mag core memory bank. hand wound.
next to and 8 inch floppy.
Jan 21, 2017 | HP Computers & Internet
A coma computer enthusiast has installed an old ISA sound card in his PC. However, it locks up and doesn?t work when a tape backup unit is used on the system. What is the most likely cause of the problem...
ISA is a very old technology and cards usually require switches or links to be set to avoid conflicts with other cards. ISA is not plug-n-play like PCI or PCI-e.
The software talks to an ISA card by knowing parameters such as IRQ number, DMA number, address range. These values may be permanently set on some cards, while others allow changing via the DIL switches or jumper links. To get two ISA cards working in one PC, the two cards need to use their own IRQ, DMA & address ranges. Make sure there are no conflicts of settings on the sound card and the tape drive card.
Try changing the settings on one of the cards. The tape drive may be the easiest for this. The tape drive is probably connected via a ISA to SCSI interface card. This should have DIP switches or Links to allow the above settings to be changed.
Oct 08, 2011 | Creative Labs Sound Blaster Live! 5.1...
Will a soundblaster ct4180 work in a del demension 3000 computer
Hello Nathan, hi, Nope, the CT4180 is to old for your dimension PC, the sound card uses an ISA slot. Your dimension has no ISA slot.
Sep 25, 2010 | Creative Labs Sound Blaster Live! 24-bit...
Pc Freezes when attempting to access HP SSL-1016 Ultrium 460 Tape
I have to admit this is a tough one. You seem to have tried most things i would try 1st.
I would suggest trying to download an eval coy of another backup program such as backup exec 12.5 from the symantec website and trying that.
This enables you to eliminate the backup software from your enquiries and if you also enable BUEX to use its own drivers (rather than the standard windows drivers) then that is another thing eliminated.
http://www.trilan-it.com/ are pretty good near the Berkshire area if you need a field call to help sort the issue but i would try BUEX 1st as that will help diagnose the problem even if you dont wish to continue with their software
Apr 16, 2009 | HP StorageWorks 18 Ultrium 460 Autoloader...
MOB ITOX G4620-N won't reconize ISA Cards
WOW must be a fairly old system if it still has ISA slots.
Are you running XP or something else?
I assume you have the manufactures drivers that match the operating system you are using?
Have the isa cards worked in this system before?
My memory of isa cards is they are really useless at managing interrupts and I/O addresses. Go into device manager and see if there are any conflicts.
Try installing one card at a time. once it is recognised you can try the second one.
Also go into the bios settings page and turn off devices you are not using like serial ports and parrallel ports. if you have a sound card remove it or disable it if is onboard.
If you know what Interupt the cards is tyring to uses you should be able to reserve it in the bios so that plug and play devices won't touch it.
With a some trial and error and a combination of all these settings you should be able to figure it out.
Apr 01, 2009 | Computers & Internet
Replacing a sound card for a dell dimension 3000
Check if your PC has a PCI slot. It is this white strip on you motherboard. Go to your PC shop and ask for a PCI sound card. Just insert it and install the Drivers CD. If it doesn't, You may have the old ISA slot and stores may not be available of any ISA sound card. But dont worry, generally all computers starting from pentium 2 has a PCI slot. You may worry only if your computer is as old as the 486 computers.
Oct 22, 2008 | Dell Dimension 3000 PC Desktop
ISA sound in Linux
Dear.
Since version 7.3, Redhat have removed support for ISA devices. If you have a older computer that uses an ISA sound device (such as my Asus L7200 laptop with Yamaha OPL3 chip), the ISA device will not be recognized. What you need to do is to download the ISAPNPTOOLS package. Unzip and untar the file and then follow the readme file's instruction to compile, install and configure it. You will also need to add the sound device module to /etc/modules.conf. After that the sound should work. Refer to the Linux Howtos for more information.
Since 2005, Linux ALSA sound architecture support pretty much have eliminated that issue even for ISA sound devices.
Oct 19, 2008 | Computers & Internet
Sound card problem
Apr 24, 2008 | Creative Labs Sound Blaster Live! 5.1...
New tape drive
Didn't realize i had to install a Veritas tape driver to allow Veritas to see the drive.
Mar 24, 2008 | Veritas Backup Exec 10 for Windows Servers...
Bus Priority PCI - ISA
actually there is a solution for this
i found a usb 2 driver somewhere and now i can attach ipods to my compaq same model as his
Dec 31, 2007 | Compaq Deskpro 2000 PC Desktop
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
