Question about Yamaha RX-V2700 Receiver
Yamaha rx-v2065 turns speakers off and displays decoder off
Kimi
  • 277 Answers
SOURCE: Yamaha rex-v390
Modern home-theater components monitor themselves electronically for potentially dangerous malfunctions such as damaged internal parts. When a unit's microprocessor senses a problem, it will typically shut down so that no further damage -- or potentially dangerous disasters like fire! -- occurs. Your receiver is identifying something upon turn-on and shutting down as a result. My guess is that you're going to need service for your Yamaha. There's likely no fix that you're going to find. You need a professional service technician.
Posted on Dec 12, 2005
robotek
  • 1512 Answers
SOURCE: Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Posted on Feb 16, 2008
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Posted on Feb 23, 2009
  • 127 Answers
SOURCE: Yamaha front panel display dim
You can change the LCD brightness in the Setup / Display menu.
Posted on Mar 02, 2010
My Yamaha V2065 receiver shuts off when i increase the volumn
Since it comes working again, immediate solution would be
• to tone down a bit your volume, check the speaker settings
like "small" or " large"
• and see if it subsides,
if not check the main amps integrity and the speaker systems.
Speaker Systems
• These would be connecting each speaker one at a time to find
the cause.
Sep 26, 2012 | Yamaha RX-V2065
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
Hi i have a yamaha rx-v995 reciver and just percase new pioneer dv-320 dvd. it's output connection is with coaxial conector.when i connect the coaxial to the coaxial onector of my yamaha reciver i dond get...
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Nov 16, 2009 | Yamaha RX-V995 Receiver
Mp3 connect yamaha rx-v995 ---> muddy sound
Try getting into the configuration menu of the MP3 player and adjust the output controls for external devices....it sounds to me like it might be too high and/or the wrong output decoding.
May 09, 2009 | Yamaha RX-V995 Receiver
Cannot get my yamaha rx-v663 to decode DolbyTrueHD audio of get my SBL/SBR speakers to work without turning the bi-amp on.
You should always connect with HDMI when using and decoding HD sound formats. If you use the normal digital option it will use PCM. Also check if your source is set to HD formats via HDMI connections.
Mar 06, 2009 | Yamaha RX-V663 Receiver
Cannot get yamaha rx-v663 to play DDTrueHD or DTS HD audio
If your Blu-Ray player has TrueHD or DTS-MA decoding, then it will send a already-decoded audio signal to your receiver. The receiver should then just recognize this as "Straight" decoding, because it isn't actually doing any decoding.
Hope this helps.
Mar 01, 2009 | Yamaha RX-V663 Receiver
Hi Dush
regards
Graeme
Sep 16, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V2700 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
