Question about Kodak EASYSHARE 5100 All-In-One Printer
Print head problems
They trobleshoot the problem with mine and sent a replacement printhead. It has a web sight to go to for installing the new printhead with it and it doesn't go anywhere??? www.kodak.com/go/printheadsupport try it it won't get me any help. Frustrated Its ony 10 months old and hasn't worked for two months. D
  • 6 more comments
  • Twinraiser Oct 28, 2008
    Tried the website for the same reason and also got nowhere!!!! Anyone know what to do?
  • rbl67 Oct 30, 2008
    printer dos not print problem whith printhead
  • hmaxwell Feb 18, 2009
    printer wont print.i got a new print head said go to www.kodak.com/go/printhead support.nothing there.this is aESP3 easyshare
  • Anonymous Feb 26, 2009
    I had the same problem...cannot remove 1st printhead...to replace the new printhead was sent from tech that I talked with...results is my Kodak Injkjet Printer just prints a blank page.
  • hkward001 May 07, 2009
    I have the same problem and I have pressed the release button as hard as I can and it will not come out!!!!!! This is ********! I have taken it out before but now that I have the replacement I can't get it out. Worst hundred bucks I have ever spent!!!
  • Anonymous May 09, 2009
    same problem... this thing is a piece of $%&
  • NO ONE
    NO ONE Feb 28, 2014
    THIS KODAK PRINTERS ARE A PIECE OF JUNK. AND THEY DO NOT AND WILL NOT STAND BEHIND THERE PRODUCT. I SHOULD HAVE KNOWN SOMETHING WHEN THE PRICE OF THE INK SHOT UP AFTER THEY TOOK THE PRINTERS OFF THE SHELF.
  • Anonymous Mar 29, 2014
    Jammed print head error. Print Head is stuck. How do you unstick it?
    Problem Solver:
Take ink cart. out, there is a release button center top just below the hole in the middle of the print head. That releases the print head take out at an angle. Hope this helps!!!!!!!!!
Posted on Oct 28, 2008
    Genius:
  • 1,605 Answers
The website or the link get you to the place. shows you step-by-step how the printr head is to be install.
if you don't have the printer, then all bets are off.
this is what I get out of the web site.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
it is fair easy, remove all print cartridges, remove the print head by unlatch it (pull up and front).remember how it was seated in the carrage.
left it out.
to install the new one, remove the 3 plastic portective shields and reset it in the carriage. and snip it in place. install the ink cartriges.
The printhead just will not come out...I've done everything you said to do but it is just not working!!! Help!!!
Posted on Feb 03, 2010
Additional problem: Where do you find the print head on printer to clean as you suggested?
I have the MP610 model, which may very well be similar. I recently had to buy a new printhead because I did not use the printer often enough and no end of deep cleaning would clear the blockage on one of the ink jets. Not cheap, so if you could share the advice given on how to attempt to clean a printhead, I would be very grateful.
I did hear you could clear blockages by running hot water over it, but the engineer from Cannon said there was nothing I could do - but then he would would't he. I noticed he insisted he took my printhead back for refurbishing, so it can certainly be done, if you have the right solvents and know-how.
If it helps, you get to my printhead by lifting the two 'lids' as you do when you replace the ink cartridges. You take out the inks; use the lever and the printhead pops out. If you assembled the printer when it arrived, it is just a simple reverse of that procedure. The same inks can be replaced later; the engineer said there would not be an air-lock problem.
Let me know if that works. I can look more closely at my printer to be more specific if that would help.
Please advise on removed print head cleaning.
Nov 11, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printhead (R), Check Printhead - Canon IPF5000
that confirms Right Print head is may be Out of Ink or near to low ink level.
check whether there is any option to Disable Alerts in printing preferences..print settings >> printer settings
Feb 18, 2009 | Canon imagePROGRAF iPF5000 InkJet Printer
Installation of printhead on Kodak 5300 All-In-One printer
Its hard to find but there is a black release button above the bullseye, press up on it and the
printhead will release, take out same way was put in.
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My kodak 5100 will not print. Sent an e-mail on 12-25 -08
try try again..........check that the print spoller is on in device setup
I had this problem;
Printhead replacement instructions are in the users guide.
THIS WORKED FOR ME --AND IF YOU CALL THE TECH SUPPORT # KODAK WILL SEND YOU A REPLACEMENT HEAD........
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
TO RUN SELF TEST
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
REMEMBER; IF YOU THINK THE PLASTIC WILL CRACK U ARE PRESSING TOO HARD....... KEEP IT CLEAN, BE SAFE
Dec 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Replacing printhead in Kodak 5300 All in One Printer
on this website:
You can find illustrated instructions on how to remove the old printhead, as well as on how to put the new printhead back in place.
You can easily go to that website by going to:
and selecting the second option "installing new printhead".
Nov 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5100 Wont Print In Color Or Black
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-421-6699cb_transparent_r.gif.
Jun 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 Printhead problems
Return the printer to the store. I had to do it myself 3 times. First I got a 5100 with the printhead error, got a replacement the day after the scanner was producing distorted  image. Upgraded to a 5300, the scanner wouldn't work at all.  To avoid problems get yourself a Canon or Epson.
Apr 11, 2008 | Office Equipment & Supplies
Kodak Easy Share 5500 will not print anything with black in it
Go here:
http://www.kodak.com/go/aiotroubleshooting
Within the tool, select Print quality, then No black, missing text, or text quality.
After answering all the questions (assuming you haven't abused your printhead) you will be prompted to enter a service number, name, and address to be mailed a replacement printhead.
I just went through this and was told my printhead would arrive in 2 to 5 business days.
Feb 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
Print heads
I've had this problem on and off for quite a while now. I find the printhead problems are due to ink drying overnight and the printer cleaning mechanism failing to wipe it off (that doesn't work properly as the machine ages). An error comes up then that a printhead is 'bad'. I remove the printhead and clean it with a propriatory fluid (which is meths basically)and that cures the problem. However it is vital that after cleaning you wipe the printface and all the contacts dry, and I mean absolutely dry, with a tissue or similar. It must be totally dry or the error is reported again. I periodically give this treatment to all the printheads as the machine doesn't wipe them clean anymore like it did when new. Hope that is of some help.
Mar 14, 2007 | HP OfficeJet D135 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
841 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
