Maintenance requise code h4-00 - Office Equipment & Supplies
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
Maintenance required code TA
This is a scheduled maintenance error. It can be reset, but if you see it on the screen you likely need some preventative maintenance. If you're in the Houston, TX area we'd be glad to be your servicing dealer.
Feb 24, 2014 | Sharp MX-4111N Copier w/ 36 Month Warranty
APRES CHANGEMENT DU TONNER LA MACHINE AFFICHER MINTENENCE REQUISE COD F2-04
la cartouche d'encre n'est pas installe correctement ou bien elle est incorrecte , essaye avec une autre cartouche de la meme marque et soit sur qu'elle provient de la maison sharp
Oct 15, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-M276 m affiche maintenance requise code:U2-40,rien ne marche.je rallumer à plusieurs reprise ça ne marche pas.que faire?
it is IC conector problem.pull out the cartridge and put it into the copier again.if the problem still exists change toner cartridge.
Aug 15, 2010 | Sharp AR-5316 Advanced Digital Imager...
Maintenance code TA does the printer go offline
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Jun 05, 2010 | Sharp MX-2700N Color Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Aug 01, 2009 | Sharp Office Equipment & Supplies
Phaser 8400 error code 37,016,43:7052
From the service manual:
37,016.4x - PEST_FAULT_HM_CLUTCH_DISCONNECT
PEST - Head maintenance clutch disconnect. The head maintenance clutch is not
drawing the expected power from the supply.
1. Run the Head Maintenance Clutch test.
2. Check the Head Maintenance Clutch wiring.
3. Disconnect the Wave Amp signal cable from the left
side of the Electronics Module. If the error code
changes, replace the Wave Amp.
4. Replace the head maintenance clutch.
I have the full service manual available should you need it. Thanks and please take a moment to rate this solution as fixya.
Feb 22, 2009 | Xerox Phaser 8400 Laser Printer
8400 fault code
Sep 03, 2008 | Xerox Phaser 8400 Laser Printer
80 people viewed this question
jasbo
jasbo
