Question about Ariete Cafe Retro Espresso Machine
Where do i find spare parts fora Ariete expresso machine model 1377
I need the plastic nossle which fits to the end of the steam pump pipe
2 Suggested Answers
SOURCE: I can not get my
Once you have put the water into the reservoir, you have to turn the machine on (top button) and then let it heat up for 8 - 10 minutes before you turn on the espresso maker button (middle button). Once you're halfway through making your espresso, I would recommend turning on the frother button (bottom one) in order to get up the steam if you're going to make steamed milk.
I hope this helps.
Posted on Oct 28, 2011
How do I open to remove the water on an LG tromm front load washing machine to repair/replace the pump?
LG machines normally have a small diameter rubber pipe folded up in the drain pump basket area on the lower left side of the front panel.
Pull out the pipe and remove the small plastic end stopper to allow the water in the tub to drain.
Sep 20, 2014 | LG Washing Machines
I can not get my expresso to come out, I had no manual with this product. Ariete elisir cafe model 1331
I hope this helps.
Jul 26, 2011 | Ariete Cafe Retro Espresso Machine
Hi, I have a Cafe Chic coffee/expresso/cappiccinno maker that has not been working properly. When I try to make coffee, the water that is suppose to travel through the filter and coffee grains ends up...
obviously you have leaking steam valve, use my recipe for rearing it:
you should take out the knob first, than you try to disassemble the SHAFT of valve from the valve body, in this types(small espresso coffee machines) usually producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal workshop where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
PS: notice you only polish the SHAFT , don't let them to short the more than 0.5 mm
Mar 03, 2011 | Espressione Cafe Chic 1377
Hello - I have a starbucks barista athena. It is not pumping when I prime or brew. I've waited until it's cold, I fill it with water, turn it (steam switch set to off) and open the steam valve and get a...
My father gave me the machine as it was sitting in his basement and it was doing the same thing. If you are not handy, try and find a shop that repairs Serco expresso machines. I didn't want to pay the labor charges and it is out of waranty so when it didnt work I took the cover off to have a look. The pump obviously was the culprit. I took the pump out of the machine and took it to a shop that repairs Serco machines (they made these). The new pump cost me $CDN 65.00 and voila it was working again. The tech said the mechanism probably got dried out inside. You can find the pump on the internet (Ulka EX5).
Just make sure you take off the right angle connector at the end of the pump that leads to the boiler, you will not get this piece. It also doesn't matter if you get the one that has a plastic part coming out of the pump instead of the copper one on the factory installed unit.
Jan 28, 2010 | Estro Barista Athena
Francis Francis X 4, milk steam not working !
Is it coming out something at all though the steam nossle? if tis not its probably blockage in the steam pipe, trie and clean it.
if its dripping och just coming out alitle water from the steam nossle i would trie and descale the machine.
Jul 15, 2008 | FrancisFrancis! X4 Espresso Machine
Ariete Cafe Retro Espresso Machine Logo
23 people viewed this question
Top Ariete Coffee Makers & Espresso Machines Experts
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Ariete Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
