Steps to take when connecting canon 2520 to a network
I want to caonnect my canon image runner to the network
Can i share canon printer on xp os?
Posted on Jan 02, 2013
  • 86 Answers
SOURCE: canon Image runner 5000
Have the IP addresses changed ?
Is the copier set with auto IP ?
If either is Yes you will need to set the machine IP address.
Set the IP-Subnet mask-Gateway adresses
you can do this by pressing the additional functions button
( the* button That is in a circle)
then id management (bottom L/H col)
then network settings (2nd to top R/H col)
then protacol settings
then TCP/IP settings
Then change these settings to the desired settings
Then go to your computer and make sure the print driver has
the same settings
Go to your computer
Go to START
Go to CONTROL PANEL
Go to PRINTERS and FAX
Then either change or check settings or add a new printer
If you need further help please get in touch
thank you
Posted on Feb 21, 2008
Cogz
  • 1326 Answers
SOURCE: Canon Image Runner 8500
You need to download it from Canons web site..
Posted on Feb 07, 2008
SOURCE: Canon Image Runner C3200 GPR 11 Drum Units
error code eo-20 on canon pc740 without replacing drum/toner unit
Posted on Nov 19, 2008
  • 168 Answers
SOURCE: Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Posted on Dec 17, 2008
color_50
  • 22 Answers
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Posted on Mar 14, 2009
Canon image runner ir 2520 says load paper but the paper is already on the paper tray please help
To fix the error:
- You select setting
- Device Settings
- Plain Paper Feed Settings
- Set up on Rear Tray instead of cassette
Oct 30, 2016 | Canon Office Equipment & Supplies
Give me the solution for my canon image runner 2520 photocopier which shows error code e000002?
Well try this method unplug for 30 second and plug it back push start and off button at the same time and hold it for 10 second and let it go then try to text copy and see if it work
Good luck
Jan 21, 2015 | Canon Office Equipment & Supplies
Error 0099 canon image runner
0099 : SMART PANEL Canon-IR-2520-2525-2530: A memory communication reservation has been cancelled.
Looks like it was answered here for a different printer -
http://www.fixya.com/support/t7156967-canon_ir2020i_dasnt_print_error_code
Sep 09, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
HOW TO FIX ERROR CODE E000000 ON CANON IMAGE RUNNER 2520
I have tried to reset error code e 000000 by putting *28 at same time * then ok, still the same problem
Feb 08, 2013 | Office Equipment & Supplies
CANON IR2520 SHOWING ERROR CODE 804
In my experience the 804 error code relates to the location/availability of a file. If you are trying to print/access a particular file check the path and make sure you have permission to access it.
Dec 28, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
My canon image runner 2520 has been duly bought and well powered, but it brings error code e000020 and it does not print or scan,i need immediate help.
the problem is when i have replaced the drum of my canon ir 2520,appeared for me two big black lines and then appeared that code :e000196.thankssssssss.
Jul 20, 2011 | Office Equipment & Supplies
130 people viewed this question
jasbo
jasbo
