Question about Sharp AR-M277 Black and White Copier
Sharp ARM162 faint copies
I am getting faint copies and prints on half of page.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Your macchine might need a PM
A few possiblities
Open the right side there is a transfer on the piece that slides out, That is the Transfer, check the wire see if it is broken, if it is broken, call a tech, or if not broken try to clean this with a can of air.
The charge might be dirty, the developer might be bad, is the machine level?
Could also be in need of a new drum.
The optics might be dirty.
But most likely a charge somewhere is dirty, or the developer is bad.
I would call a Tech for a PM (PM is new drum, developer, charge, and a decent tech will clean the optics and machine)
Posted on Oct 23, 2008
Do I have to call a service
it means fuser temperature is abnormally low, check halogen bulb works , then check thermistor, and thermostat ,
Jul 24, 2014 | Sharp AR-M162 Toner Cartridge ARM162...
I have a sharp sf2116 copier. when copying i am getting half of the page printed properly but the other half is feint. i have renewed the toner.
problem is not the toner , could be the developer unit stopping at that point when it becomes feint and then no new toner gets to the drum,
it could be the transfer section
Aug 06, 2013 | Sharp SF 2020 Copier
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
Sharp copier, not producing clean copies
Check the fuser roller if it still has faint prints on the roller then your getting a shadow image in your prints,. Could be a bad fuser roller replace it
Mar 24, 2010 | Sharp Office Equipment & Supplies
Only copies half a page. Right margin cuts off
check paper trays to make shure paper is tight in guides. registration settings off
Jan 09, 2010 | Sharp Office Equipment & Supplies
Copy split in half; half blank/half print
It is a scanner problem. You need to take in in for a service tech to repair. It could be the scanner bulb, or laser.
Jan 08, 2010 | Sharp Office Equipment & Supplies
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Sharp AR168D won't copy
There are small mirrors on the copy lamp, wipe with a clean dry soft cloth. Remove the drum unit and wipe upper part where the drum unit was and make sure the area is clean.
Mar 31, 2009 | Sharp AR-235 Copier
Incoming fax shows one half of the page
The Thermal printhead is most likely burned out on one side and will need replaced. It could also be the printhead connector has worked loose and is only making partial contact. Remove the connector and reinstall. If that doesn't solve the problem then it would be cheaper to purchase another fax.
Jan 22, 2009 | Sharp UX 108 Roll paper Thermal Fax
Sharp AR-M280N- Printing dark lines
It sounds like you are going to need a new drum and drum cleaning blade. How long has it been acting up? When was the drum last replaced? The image repeatting could also be coming from the UFR??? It really depends on how many copies you have on it and has it been seatting for awhile..... Need some more info... But you most likely will not be able to fix your self..
May 19, 2008 | Sharp AR-M280N Copier
Sharp AR-M277 Black and White Copier Logo
126 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
