Question about HP 2025 20.1" Flat Panel LCD Monitor
Resolution I hooked up this monitor and the icons on the desktop were about two inches big and blurry. I changed the resolution to the recommended settings and the icons are almost as big as my face. Could this be the video card?
  • adodas Oct 27, 2008
    Must be the craphics card...Thanks!
  • 903 Answers
It is definatley something to do with the graphics card. Or just the settings you have set it to. Have you tried pressing the auto set button on the monitor itself to see what happens? other to that if you can set the display settings to 1680 by 1050 and display it to highest 32bit. If it doesn't let you do this then you definatley have graphics card issues.
Posted on Oct 23, 2008
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
I just installed win7 and all mi icons are big, everything is big, please help me.
Right click on the desktop and go to personalize. Down in the bottom left corner click Display. Choose smaller 100%. If this is already checked, Right click on the desktop and click screen resolution. Pick a higher resolution and click apply. The higher the number the smaller everything will get, For Example. 1280x 720 is much smaller than 800 x 600
Mar 12, 2011 | AOC LM560 15" LCD Monitor
I want to install the monitor Hyundai L70N but I don't have any cd
You usually do not need a disk to install a monitor, most of them are plug and play capable. If your getting an image that is blurry and out of perspective you may need to change your display size " standard 17 inch is 1280x1024 " If your on XP you can right click on the empty desktop and go to properties, Under the settings tab you will find options for screen resolutions. If your on Vista or 7 you right click on empty desktop space and go go screen resolution, There again you will easily find your settings for your screen resolution. Click apply and then click OK. If your still encountering problems such as no image at all you may have a problem with the monitor.
May 09, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
I have just got this 22'lcd Samsung 225ms. I cannot seam to fix the problem of blurry letters. This can be very hard to read even at a distance. I have searched for updates online for my nvidia g force...
This monitor will only have a sharp image at a resolution of 1680 x 1050. Any lower setting will result in blurry images.
In an LCD the pixels are fixed, and using any resolution lower than the optimal will cause blurry images. This is called Image Scaling:
http://en.wikipedia.org/wiki/Image_scaling
If that resolution causes the icons to be too small, you can change the DPI setting to 120 from 96, that will make them larger
Jun 09, 2008 | Computers & Internet
Text/picture shadow
This could be caused by any number of things. The first thing I would check is to make sure you have the cable plugged into both the monitor and the computer snuggly and that it hasn't come loose (if you haven't screwed the cable in using the thumb screws then you should). If this doesn't fix the problem I would check to make sure you are using the recommended resolution and refresh rate for your monitor (this can usually be found in the manual or if you change these settings some monitors will even tell you what the recommended settings are if you set them to something other then what is recommended). If you are using a Windows based PC you can check your resolution by right clicking anywhere there is a free spot on your desktop and choosing properties (or personalize if you are using Vista). This should bring up your display settings. If you click on the Advanced button and then click on Monitor you can change the refresh rate also. If you set it to something wrong just do not hit any keys or press any mouse buttons for 15 seconds and your computer should automatically revert to the setting you were using before. If none of these works and the cable running from your monitor to your computer is detachable then replacing the cable is recommended. Replacing it with a shielded cable that is gold tipped will provide the best connection (espically if you are using a longer cable). If none of these works you could have either a bad monitor or a bad video card. If you have a second monitor available I would hook that up and see if you see the same problem. If so, and you have already tried the resolution/refresh rate settings, it is quite possible your video card is going bad.
May 09, 2008 | Gateway FPD2275W LCD Monitor
19 inch tft lcd monitor blurry
go to control panel click on display icon and then go to setting tab and there you will find screen resolution settings
Apr 29, 2008 | Gateway FPD1975W 19" LCD Monitor
HP 2025 20.1" Flat Panel LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
