Question about Philips Office Equipment & Supplies
"INSERT THE TONER CARD" Philips MFD 6020
What if I don't have a card? My printer started to show this after a power cut... Is there a way to reset this error without a card? Buying a new cartridge to use its card and trowing away the old one, which is 50%-ish full is not exactly a solution. And if then the message does not go away, it would mean that my printer is damaged.
  • 1044 Answers
SOURCE: Hi I bought a new printer Philips Laser MFD 6020
Go to this site and download the drivers for your printer.
ptf.com/philips/philips+laser+mfd+6020+drivers
Posted on May 19, 2010
rylee_smith
  • 8619 Answers
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
  • 6 Answers
SOURCE: hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Posted on Sep 12, 2009
  • 661 Answers
SOURCE: why want my philips laser mfd 6020 print in colour
Laser printers can't print in color. Thats why.
Posted on Feb 03, 2011
How do i download and install my philip laser mfd 6020 printer
Go to Philips.comsupport, and click on "contact". Have the full product number available. Pose your question to Philips. Usually going directly to the source, will bring you the best results.
Jan 04, 2015 | Laser Office Equipment & Supplies
I have a Philips MFD 6020 printer. Anytime I turn it on, it displays the message 'Receiving File' and sometimes 'Writing File'. The buttons have ceased working and it won't print. Pleae help.
all wrong, the flash memory does not save the firmware and because u have removed power too long you have to upload the firmware;
I have the same problem
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=gr&mid=Link_Software&ctn=LFF6050/INB
for the firmware
use the software companion suite to upload the firmware and it will work
Aug 02, 2013 | Philips LaserMFD 6020 (LFF6020)
How do i connect my philips laserMFD 6020 printer to my computer without a cd?
Without a CD, first of all you need to go on google and search for philips website. Enter your product as Laser MFD 6020. This will take you to a page where you will see all the info on it including software and drivers with an option to download. Once you download, connect your printer to your computer using a USB Cable. After that reboot your computer should detect it and follow the instructions to install. I hope this will help.
Jun 26, 2012 | Philips LaserMFD 6020 (LFF6020)
Printer is reading INSERT THE TONER CARD, after replacing the toner cartridge
You need to replace the chip card that came with the toner.
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=LFF6020W/GBB&dct=QAC&faqview=1&refdisplay=QAC_80832&refnr=0080832&scy=GB&slg=ENG
May 14, 2012 | Philips LaserMFD 6020 (LFF6020)
On Xerox Phaser 3100mfp., after refilling the toner its asking "insert toner card"
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Hi I bought a new printer Philips Laser MFD 6020 but I am unable to install as the CD is not helping, since it said cant find the hard drive.
May 19, 2010 | Office Equipment & Supplies
1,112 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
