Question about GPS
Wrong Time How do I set the time
  • Anonymous Nov 06, 2008
    when the clocks went back , my device didnt , i assume it does this automatically , and if not how is it donje, would appreciate a resolve . thankyou
  • Anonymous Nov 26, 2008
    I tried that and turning off the daylight savings time; however, it didn't work. I had to set mine to mountain time and turn off the daylight savings time to get the correct time.
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Posted on Nov 10, 2008
Clock has wrong time unable to change
Wrong Time Or Clock Not Set
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsAug 3, 2010 - Features ? > Clock ? > Wrong Time Or Clock Not Set Share on Google+ ... of which receive RF transmissions, you cannot use the Auto Clock Set. ... Press the ? or ? to change the value of the highlighted field and press ... If after reading through the previous troubleshooting steps you still have questions, ...
iPhone/iPad Has Wrong Timezone When Date/Time is Set
Dec 28, 2015 | Audio Players & Recorders
My voicemail displays the wrong time the message is left. How can I fix this problem?
This is what happens when you have the wrong time set on your machine. It is important for you to know that telecommunication devices make active use of the time on your device to present information to you. In real sense, it presents information to you in accordance to your device time and if you have a wrong time set, you are likely to have a wrong time on the information that would be presented to you.
The best solution is to reset the time on your device and it should be good.
Hope this was helpful? Please comment for more information and thank you for using fixya.
Jan 24, 2011 | Cell Phones
Time time is wrong
From the main menu, select Change Preferences.
From one of the Preferences screens, select Set Clock. Choose the format that you want the time to display, then set the correct time. The Sync button will take the time from the satellite.
Nov 03, 2009 | Tomtom GO 300 GPS Receiver
Tv listings clock at wrong time and recording the wrong show
Check the time zone setting in the STB. If after the power cut the STB settings got scrambled they could have defaulted to the wronge timezone. This would make the program guide times wrong.
Jun 21, 2009 | Sony DHG-HDD250 200-Hours Video Recorder
Wrong time
go to phone settings and click time and date and set the time
Jun 03, 2009 | Cell Phones
My PC takes very long time to get started. Disk checking shows "Invalid time set up". Dialogue box shows "CMOS WRONG". drjsil@yahoo.co.uk
just reset your computer time if it is not on the taskbar do it on the control panel. or you can set your time in the bios set up.
May 03, 2009 | Computers & Internet
Timing settings
my jeep has jumped time and i need to know the exact degrees to set it at please and thank you.
WRONG!!! WRONG!!! WRONG!!!
The first thing you need to do is to find out why it jumped time. Jumping time is not normal and shouldn't happen.
Tell me the last repair that was done on the jeep.
When was the timing belt last changed?
Were OEM parts used?
Were tensioners and pulleys changed?
Dec 27, 2008 | 1995 Jeep Grand Cherokee
Equity 44100 clock radio problem
Hold the Alarm Set button down for about 5-7 seconds. The year will flash. Skip the year and date by pressing Alarm Set a couple times until the time is displayed. Use the Up and Down to change, then press Alarm Set one more time to save it. This clock is ****, by the way. I run into them in hotels and it makes me nuts as well. Very non-intuitive.
On the time lost issue...there is a button battery (CR2032) in a compartment underneath. That battery keeps the internal time so when the clock is plugged in, it "instantly" sets the time. Problem is, if the internal time is set wrong, then it instantly sets the wrong display time when it it plugged in. See procedure above to correct that.
Jun 10, 2008 | Equity Time USA Sky Scan 44100 Clock Radio
Wrong date and time
Your GPS receive its date and time from satellites. Take the unit outside and acquire a satellite fix in order to update your time and date. You can set the time zone and time display (12hr, 24hr, UTC) under the unit setting.
Jan 12, 2008 | Garmin nuvi 350 GPS Receiver
HP compaq d530c timer running fast
you may check and see if it's set to the "internet time" -> "automatically syncronize with an internet time server", if there you have a wrong server, then it'll reset your time wrong, or if you have another timezone set in windows, than it'll update to that timezone.
secondly, if it's a hardware related issue, than it can be the battery
Jan 09, 2008 | HP Compaq d530c PC Desktop
GPS Logo
443 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
