Question about Dual XDMR7700 CD Player
Need a connector pinout diagram for a Dual XDMR7700 car stereo
I need to find out the wire arrangement on the pwr/spkr connector that plugs into the back of the XDMR7700 Dual car stereo.
3 Suggested Answers
  • 4 Answers
SOURCE: i have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Posted on Nov 09, 2008
drsinister69
  • 2317 Answers
SOURCE: need a wiring diagram for this radio
Here is a link to the stereo's owner's manual which will tell you how to hook it up:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/070/070XD7500.PDF
Posted on May 18, 2010
18c808 aa subwoofer with amp from Focus. How do I install it?
ask here
http://www.f150forum.com/f75/how-fix-your-subwoofer-amplifier-7l2t-18c808-aa-227544/
or
Diagram 7l2t 18c808 aa - Dual Ford Mustang Convertible 94-12 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
Oct 23, 2015 | Ford Cars & Trucks
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
What are the black and orange wires for on a Dual Xdmr7700 stereo?
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 07, 2010 | Car Audio & Video
Replace factory stereo with after market for 98 Dodge Ram 2500
Right Rear Spkr (-) Blue w/ Orange Stripe
Right Front Spkr (-) Blue w/ Red Stripe
Right Rear Spkr (+) Blue w/ White Stripe
Right Front Spkr (+) Purple
+12 Volt Ignition Wire Lite Purple w/ White Stripe
+12 Volt Battery Wire Pink
Left Front Spkr (-) Brown w/ Red Stripe
Left Rear Spkr (-) Brown w/ Blue Stripe
Left Front Spkr (+) Green
Left Rear Spkr (+) Brown w/ Yellow Stripe
ground would have to be connected directly to vehicle's frame
Jun 05, 2010 | Car Audio & Video
Pioneer DEH-17 wiring diagram or pinout connection
the groung wire was torn out of my deh1700 pin connector where does it go back
Dec 10, 2009 | Pioneer DEH-1700 CD Player
I have a ASE380-UD440A PC. I need Pwr Supply wiring diagram.
It should follow the standard AT or ATX convention try this site
http://pinouts.ru/Power/
click on power supply connectors
Mar 14, 2009 | Acer Computers & Internet
Car wiring
If you have a factory amp, then here's the wiring:
blu/yel 12volts
gry 12volts key on
pink, violet left front spkr
grn, blu rt frt spkr
blk, yel Lt rr spkr
red, wht rt rr spkr
brn ground
If no amp, then:
blk/red pwr ant.
gry 12v key on
blu/yel 12v
wht/grn and grn interior lights (dimmer)
speaker colors same as above
brn ground
Note, these are for 97 camry
Jul 13, 2008 | 1997 Toyota Camry
Wiring diagram
Try Crutchfield.com. They may have a wiring diagram that you can download. They certainly have adaptor harnesses. So you don't have to cut the factory connectors off.
May 27, 2008 | 1995 Ford F150 Styleside Regular Cab
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Dual XDMR7700 CD Player Logo
170 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
