Question about NEC Electra Elite DTU 16D-2 Corded Phone
Nec dterm series i dnd on
How do I turn it off?
To turn off DND press feature, dial 69 press feature again. Hopefully this works, I tested it on my phone and it worked. I have an Electra Elite.
Posted on Nov 03, 2008
  • 149 Answers
SOURCE: How do you remove the DND feature on phone model NEC Dterm Series III?
Feature 69 feature.
Posted on Nov 13, 2008
bhur
  • 85 Answers
SOURCE: cant turn off dnd on
need to reflashing your phone.
Posted on Jul 19, 2008
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
  • 12 Answers
SOURCE: I have a NEC Dterm Series I phone. I inadvertantly
If you have a key system try dialing 42 or 69, If you have a pbx try dialing #8
Posted on Jan 06, 2010
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Pls help to solve my problem NEC telephone IP2Ap-6TXD I set to DND external, how can i deactivate it please..
Feb 01, 2011 | NEC Dterm DTP-2DT-1 Phone
NEC phone
CLICK THE DND BUTTON ONCE, GIVE IT A FEW SECS AND IT SHOULD GO OFF.
Oct 19, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Nec dterm wont ring in
During an incoming call try holding the up arrow on the volume key. That is the only way I know to increase or decrease the volume of the ring. The phone might also be set on DND. in which case you have to Press feature dial the DND cancel code 69 press feature. If note look for you user guide here. http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
Aug 21, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Dterm series i phone
with handset down press speaker and then #8
Aug 01, 2008 | NEC Dterm DTP-2DT-1 Phone
Taking off DND
press "feature" 69 then press "feature" again ~ problem solved!
May 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
1,467 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
