Question about RCA RS2652 Shelf System
RCA RS2652 speaker rumble...
I've had my stereo for a little less than a year now (unfortunately cannot remember if I sent in the warranty) and the right speaker has began to rumble and overly vibrate when the music kicks up a notch. I've found that pushing in the backing of the speaker fixes the problem, but I have no clue how to permanently solve the problem. I'm thankful for this forum.
You can use wood glue and glue it back together thats what i did with mine and i havent had a problem since
Posted on Sep 23, 2007
Can I replace the speakers on this system? Speakers are too large for space & want to replace with another brand.
make sure impedance is the same so 6 ohms and the power rating of speakers is no less than 200 watts peak rms.And bare wire ports on back of speaker.
The power rating is so the speakers can handle the maximum power delivered by stereo amplifier without burning out speakers coils.
Jan 23, 2016 | RCA Audio Players & Recorders
How do I replace the fuse in the stereo for the speakers
pull the cover off and on the circuit board on the bottom of the unit you will see a row of fuses
Nov 12, 2012 | RCA RS2652 Shelf System
Speakers pop or rumble when stereo is turned on
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Apr 24, 2010 | Kicker ZR600 Car Audio Amplifier
Is there a way to hook up an ipod to this stereo so it will play the ipod music through the stereo? Can I purchase a docking station that will hook up to this stereo?
Just get an adapter for to connect from the Ipod headphone jack to a standard RCA cable pair. Jack into AUX or whatever available input you have.
Dec 05, 2009 | RCA RS2652 Shelf System
PSB Sub 5i-Starts to rumble continously when the stereo is off
Had this same problem with a Yamaha sub. Unfortunately it's the amp section in the sub. If they can't fix it in the shop (problem is they don't leave it on long enough for the problem to return), the only option is replacement. I buy exclusively on AmEx cards, because they cover this kind of stuff - an additional 1 year warranty on anything you buy.
Apr 18, 2017 | PSB Alpha Sub Sonic 5 Subwoofer
Installing self amplified sub to factory stereo
Hello Jax GS300,
Yes, you can use RCA cables. Just wire in a "low-level" converter.
Using RCA's is really the best way, allowing you to run shielded wiring to the sub, making it less likely that the wiring will pick up electrical interference. I'd install the converter on the rear speaker wires behind the dash.
If you do not want to convert the speaker output, you can drive the Kenwood directly from the speaker wires. The diagram in the install manual shows the connections coming off the rear speakers.
Here's a link to one output converter. This one will convert all 4 speakers.
http://www.crutchfield.com/p_142SLC4/Scosche-SLC4.html?search=level+converter
Hope this helps.
Apr 09, 2009 | Kenwood KSC-WD250 Car Subwoofer
Speakers blown?
first check your warranty and then contact these people and ask for assistance.
Jan 05, 2009 | Bose 901 VI Main / Stereo Speaker
No bass...
i have the same problem
Dec 27, 2007 | RCA RS2652 Shelf System
Fuses blow
In addition to what i said in the live chat about the transformer, here is a link to the manual for the RS2653 which seems very similar; http://www.rcaaudiovideo.com/rcaav06/AudioVideo/ProductDownloads/RS2653_IB.pdf or this link to contact RCA directly; http://www.rcaaudiovideo.com/en-US/ContactUs.html Hope this helps, not much in the manual of any use for this problem :)
Mar 22, 2007 | RCA RS2652 Shelf System
RCA RS2652 Shelf System Logo
83 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
