We have error 0176 system security tempered ibm thinkpad t42 notebook
  • 177 Answers
SOURCE: trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
Posted on Nov 25, 2008
  • 101 Answers
SOURCE: I CANNOT BOOT MY IBM THINKPAD 2367..HELP
Both errors are related to the backup battery which is located under the main battery. It is probably dead. You can get one on eBay for $3.29 w/free shipping or pay a shop $20 to put one in. If you do it yourself be very gentle plugging it into the tricky little slot - it is possible to break the connector loose from the motherboard but it is an easy repair if you have patience and dexterity. As for the password, try just hitting enter. It is the supervisor password to change the BIOS settings and was probably never set.
Hope this helps.
Jon
Posted on Apr 13, 2009
  • 5 Answers
SOURCE: error no 0176
Change the bios battery.Remove the notebook battery and then you should see the bios battery.Maybe you should have to disassembly the complete pc because it is a little dificult without disassembly.
  • 11 Answers
SOURCE: THINKPAD R40 TYPE 2682
search the internet, most BIOS manufacturers leave a back door for problems like this.
Posted on Sep 18, 2009
sim4182
  • 393 Answers
SOURCE: ibm t42 thinkpad t of svp password
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Posted on Sep 15, 2010
Error 0176 ibm
Lots of issues with 0176 error. Could be caused by a dead cmos battery or the system thinks it has been tampered with. I found a couple of clues for you;
The T41 Hardware Maintenance Manual gives the following instructions in case of error 0176:
"Run BIOS setup utility, and save the current settings by pressing F10."
To get into BIOS, you need to press the F1 key when you see the splash screen. I suppost that the splash screen on a T41 will display a ThinkPad or IBM logo, and something similar to "to interrupt normal start procedure, press the blue thinkvantage button".
The idea that a new motherboard might be necessary comes from the T41 Hardware Maintenance Manual. It says that in case the first instruction, i.e. get into BIOS and save current settings, doesn't fix the problem, a new motherboard should be installed.
You could try the following:
Disconnect the AC adapter from the notebook, disconnect all other cables. Remove the battery pack. Press the power button ten times in one-second intervals. Then press the power button again, and hold it pressed down for 30 seconds. Then install the battery pack again, connect the AC adapter. Press the power button.
Re: 0176 Security - The system has been tampered with
The padlock came up after removing the BIOS-battery. It is a security-feature and cannot be bypassed.
Removing the BIOS battery does not remove the supervisor-password but locks the system, if one hat been set to protect the computer from illegal use.
So either try to get the SVP from the previous owner ore replace the board.
Mar 20, 2014 | Lenovo ThinkPad R60 Notebook
Solution for system security:the system security has been tempered with
when if i type my wipro laptop key G,H,J,K,L,U,I,O,P,M etc then i see 1,2,3,4,5,6 etc, why?
kindly give me solution
e-mail/ph- ranajitsardarsv@gmail.com/8653465590
Jun 15, 2013 | IBM 14.1" Thinkpad T42 2374-Wkz Laptop -...
0176, enter CMOS setting or BIOS setting we do this but error not removed
0176 System Security. The system has been tampered with.
  1. Run BIOS Setup Utility. Then save current setting by pressing F10.
  2. System board
Feb 10, 2012 | IBM ThinkPad T42 Laptop
Says sytem been tampered with code 0176
0176 error meaning the system cover had been opened. To fix this error, you need to enter CMOS setting or BIOS setting. press F10 to save before exit. Then the error will be gone.
Did you ever open the system cover before this error happened?
Sep 12, 2010 | IBM ThinkPad T30 2366 Notebook
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Error no 0176
Apr 13, 2009 | IBM ThinkPad R40 2722 Notebook
Trouble resetting error code on my t-30,error code reads 0176
Nov 25, 2008 | IBM ThinkPad T30 2366 Notebook
Turns off autometically
How far does it get on the boot process? Does it open the operating system completely before shutting down? Do you get any error messages, and does it go to a black screen stating Windos wasn't shut down properly? Answer these and I'll have a better idea of what's going on.
Aug 26, 2008 | IBM ThinkPad T42 Notebook
Cmos password for ibm r40
You will have to remember it. IBM puts a security chip on the motherboard, the bios password is burned into this, and there is no way around it. There are a few places that will replace the chip, but they are very expensive. The only other way is to replace the motherboard. I've found that replacing the motherboard is cheaper than having the chip replaced, so, if possible, remember the password.
Jun 30, 2008 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
679 people viewed this question
David Payne
David Payne
