Question about Panasonic Microwave Ovens
Have a pansonic microwave oven model nn-sn960s it won't heat there is a code H98
Won't heat there is a code there is a code H98
  • 10 Answers
SOURCE: Pansonic Microwave Oven NN-S962-BF
Most likely the power capacitor is shorted.If you know someone that is just alittle familiar with electronics, they will know what to look for.The part will look like a somewhat long large silver 9v battery with two metal leads.Normally toward the back of the microwave and below the cooling fan.With a volt-ohm meter this capacitor can be checked.on the meter if you get a reading ,its bad, if you get no reading(open), its most likely good.Ninety percent of the time it will be bad.If it is, just replace with the same value and your ready to go.
Posted on Nov 06, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: pansonic model nn-p295 over the range microwave oven
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
  • 8404 Answers
SOURCE: microwave Panasonic H98
Please check your door safety interlock switches.
When you open the door with the oven running, to check stuff, there is an arc on the tiny contacts. Eventually, they burn and are not able to tell the oven that the door is shut. Forget what you know about the door, the oven has to be sure the door is shut and it uses these little switches for that purpose.
There are other reasons for no heat, this is the most likely one. Check them with a volt/ohm meter. If failed, get replacement from Panasonic, your appliance parts distributor in your town, FixYa.com advertiser, Radio Shack or www.repairclinic.com
Good luck with your repair.
Thanks for your interest in FixYa.com
Posted on Feb 23, 2010
heatman101
  • 43501 Answers
SOURCE: my panasonic microwave oven is not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfsghs
Posted on Sep 30, 2010
  • 8909 Answers
SOURCE: H98 WILL
Take it to a Panasonic Repairer as there are no user serviceable parts inside.
Posted on Mar 07, 2011
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
H98 is coming on and not heating food
heatman101 ;'
May 12, 2011 | Panasonic NN-C994S Convection/Microwave...
H98 WILL NOT HEAT CODE H98 pansonic inverter microwave
Mar 07, 2011 | Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Microwave Ovens Logo
361 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
