Ricoh sp4210n sc 543 how to clear - Office Equipment & Supplies
Bubbabear64
  • 2794 Answers
SOURCE: Product Gestetner 3245 It has sc 543-00 problem
Fusing overheat error.  It may require a thermistor or a new lamp.  Prices vary by dealer.  You would have to contact a dealer in your area to find out.
Posted on Sep 18, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
Ickoajnc
  • 183 Answers
SOURCE: Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Posted on Jul 15, 2009
Ickoajnc
  • 183 Answers
SOURCE: service mode
Press the “Up/Down arrow” keys together for about 5 seconds, and then press the
“OK” key.
“SYSTEMver x.xx/ 1. Service” appears on the display.
The machine automatically goes off line when you enter the service mode.
enter SP 5810 and reset the SC 543 **** if again appears please do not reset it again because you may do bigger problem and damage more part than ware damaged in first place .
The SC code says that the termistor is damaged so check on the fusing unit dose the termistor is standing in good position or has dirt on the surface of he termistor.
RATE ME IF THIS HELP YOU
Posted on Jul 17, 2009
  • 990 Answers
SOURCE: sc 322
Hello sir; Try to reset if not work you need to replace laser unit, the reset procedure as follow; press "clear mode " then 107 then press " clear/ stop " until screen change ,then touch "copier sp " ,then turn power off and back on .
Posted on Aug 26, 2009
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Ricoh SP4210N printer -- display keeps indicating an error -- SC230. What is SC230?
1. Connect the cable correctly.
2. Replace the engine control board.
3. Replace the laser scanning unit.
4. Check or replace the cable.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Ricoh Corp Aficio SP4210N BW Laser Print
Overheating and getting sc 543 alarm
sound like cooling fan died if so needs to be replaced asap
Jan 20, 2011 | Ricoh Corp Aficio SP4210N BW Laser Print
Service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Service mode
call service --- possible bad thermistor (fuser)
could over heat
Mar 17, 2009 | Ricoh Aficio SP C410DN Laser Printer
47 people viewed this question
jasbo
jasbo
