Windows xp how open device manager in windows xp
  • 928 Answers
You can click start then run then type in DEVMGMT.MSC
You can also click start then right click on My Computer then click properties. Go to the Hardware tab then device manager.
You can also go to Start then Control Panel then System then the hardware tab then Device manager.
Posted on Oct 27, 2008
Wireless Optical Mouse Mi-4150K doesn't connect to pc
windows 7/vista :
-step 1 :Press the windows button (start button).
-step 2 : In the search bar type device manager.
-step 3 : Open the device manager.
windows xp/2000 :
-option 1 for opening the device manager :
-step 1 : Press the windows button (start button).
-step 2 : Open the control panel.
-step 3 : Open the "System properties".
-step 4 : Click on the hardware tab.
-step 5 : Click device manager.
-Option 2 for opening the device manager :
-step 1 : Press the windows button (start button). -step 2 : Select "Run"
-step 3 : Type the following into the text box "devmgmt.msc"
-using the device manager :
-step 1 : Once the device manager is open, click on "Mice and other pointing devices" or "other devices" (if prompt).
-step 2 : In the newly open menu, if there is a "?"right click on it and press update driver.
This should almost force the computer to recognize the hardware plugged into the USB port.
Hope this helped!
Nov 06, 2013 | Trust Wireless Optical Mouse Mi-4150K
Tip
How to pin Device Manager to the Start menu
Device Manager is a handy Windows tool for managing and troubleshooting components and peripherals. There are several different ways to access the device manager, however each of them requires a few steps. For easier access, why not pin the Device Manager to your Start menu?
Pinning a program to your Start menu is a simple procedure -- just right click on the file name or icon and select "Pin to Start menu." However, the Device Manager is typically accessed from inside another window (usually either the System Properties screen or the Computer Management console), and you can't pin it to the Start menu from there.
In Windows Vista, you can hunt down the Device Manager using the Search bar (just type "device" or "device manager" into the Search bar) and right click it from there to pin it. In Windows XP, the process is a little more involved -- you can follow the same steps as for Vista, but XP's search feature takes much longer to find files than Vista's does, so you'll be waiting at least a minute or two. By the time the system finds the Device Manager, you could have already been done with the whole thing.
To find the Device Manager file in Windows XP, open up Windows Explorer (Start > All Programs > Accessories > Windows Explorer). Click the plus sign (+) next to My Computer, then navigate to C:, then Windows, then System32. In the System32 folder, find a file called "devmgmt.msc" -- this is the Device Manager. Right click on it and then select "Pin to Start menu."
on Jul 02, 2010 | Computers & Internet
Windows Xp not recognise my USB TS4GJF110
To initiate recognition of the USB device by using Device Manager, follow these steps:
  1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
  2. Click to select your computer as the location for the scan.
  3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
Aug 23, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Some USB that are attach to my pc are not recognized.
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2. uparrow.gifBack to the top Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
  2. Expand Universal Serial Bus controllers.
  3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
  4. Click the Power Management tab.
  5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
  6. Repeat steps 3 through 6 for each USB Root Hub in the list.
  7. On the Action menu, click Scan for hardware changes.
  8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3. uparrow.gifBack to the top Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Aug 14, 2011 | Computers & Internet
Gateway 310 s won't recognize a cd
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
I lost some drivers (Multimedia Audio Controller, Video Controllers VGA Compatible) and I don't remember their names and I want to found them. It's for a PC: Phoenix : Award bios V6.00PG, Intel Celeron...
You can find all your hardware drivers in on place called Device manager in Windows. Here is how you get to Device Manager.
(1)Go to My computer (in Windows 2000/XP). In Windows Vista/7 its Computer.
(2)Right click, a pop up menu will open, click Manage in the menu.
(3) A Window will open click on Device Manager. On the right pane you will find all the devices and related information listed in it.
note: There other ways also to access the device manager in Windows.
Sep 14, 2010 | Computers & Internet
MY COMPUTER DOES NOT RECOGNISE THE IPOD TOUCH AT ALL ALTHOUGH IT CAN CHARGE ITSELF
Solution 1 -
Solution 2 -
Feb 02, 2010 | Apple iPod touch
Unable to open pages...wireless connection is enabled
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 16, 2009 | Toshiba Tecra T9000 Notebook
My dell inspiron is connected to our server at work but wont open a web page while others opens,i cecked the drivers and set ip but it is still the same
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Oct 06, 2009 | Dell Inspiron 1525 Laptop
Looking PCI Device
Check Device Manager.
Open System Properties. Click on the Hardware tab than click on Device Manager. Scroll through the listed icons. If you see a yellow ! or ? than there is a device that XP is barking about.
Dec 18, 2007 | Dell (0Y4801) for Inpsiron 600M, Latitude...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
