Question about JVC AV-48WP30 48" Rear Projection Television
Jvc tv 56 convergence problem
What is the quickest way to get to the convergence board
    Problem Solver:
  • 4 Answers
On the 48WP30, you get to the convergence board through the front. Around the back edge of the speaker grille are four screws. You remove these screws. Then you remove the two other screws at the top of the speaker grille near the center panel underneath the front av input door.
THen after you get the speaker grille off, you take the four screws out of the wood panel door and take it off:
Those two big black heat sinks on the front there are your SK chips...on the convergence board of course. pop it up from those four tabs, and that will let you carefully move the convergence board so that you can reach in better, and unhook the three plugs on the right side (looking at it from the heat-sink side) behind the heatsinks (one for red, green, and blue each) and then on the other side of the board, you disconnect the other two plugs, but there's one that you actually have to trace back into the inside of the TV and unplug from a vertical standing board, since the socket is not on the convergence board itself. let me draw up a little graphic real quick.
Hope that helps.
Posted on Oct 31, 2008
Jvc hd56fn97 56-inch 1080p hdila rear projection tv with convergence problem, how do i fix this
That set cannot have a convergence problem as it has no convergence circuit, It is a DLP set with a lamp.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Hi i have a jvc tv model av-56wp30 it has a red line in the corner of the tv what seem to be the problem and will it cost me alot of money to fix?
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,B,G mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board it is dead.The tv convergence board,must require repalcing 2 STK convergence ICS and some or all of it resistors too.The tv convergence board is fix,will solved ur tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP30 56" Rear Projection...
Middle of the top of the picture in distorted and out of focus. color is displaying only purple at the top
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to fix the tv convergence board,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP74 56" Rear Projection...
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
My jvc 56" proj. tv pops several times when i turn it on but the screen stays blank
Ok, I suspect one of the two convergence chips is shorted, this is usually the most common reason the light (blue?) just blinks.
I can tell you in a easy way how to prove this without replacing any part--
What kind of skill do you have?
This entails removing the front grill under the screen and disconnecting the Convergence board behind the inspection plate.
I am here to help--
SD TECH
Oct 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Red convergence will not line up on my jvc 56 inch i art projection tv model # AV-56WP74. PLEASE TELL ME WHERE CAN I BUY THE KIT SO I CAN FIX IT MYSELF!!!
You need to pull the front grill cover/panel off the front of the tv. Remove screws (4) from back that hold it on, also 2 small ones behind front video input door. Then remove access panel. The ckt board closest to you is the convergence amplifier board. You should replace both amplifiers (stk392-110 or 120) and any burnt/open resistors you find near the amps.(use the same value resistors as the corresponding resistors in the blue amp ckt)
Jul 08, 2009 | JVC AV-56WP30 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC 56" projection tv
Replace STKs in convergence board.
Oct 17, 2008 | JVC HD-56FB97 HDTV
Tv comes on then goes black power light blinks on and off modle # JVC AV-56WP74 56
Check the coils on the main board. Coils mean round ferrite donuts (1 inch or less) with copper wires on it. I have seen this come out.
if not check convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 20, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
1,397 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
