Question about Kirby Vacuums
Turning of front part that indicates that the belt is on does not get the belt to turn and therefore the vacuum is not "sucking up" the dirt and debree.
  • 35 Answers
Raise the height adj. all the way up.Turn the beltlifter knob counter clockwise,and unlatch the head from the machine.Look thru the opening in the back to see if the belt is broken.If not,then,look thru the back to make sure the belt lifter picked up the belt.If not, then turn the belt lifter clock wise to position the hook to pick up the belt.Then,turning the knob again counterclockwise will pick up the belt.Reinstall the brushead onto the machine,and turn the beltlifter to drop the belt onto the shaft.If the belt slips off again,replace the belt shaft,as it could be wore down.
Posted on Dec 16, 2008
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Kirby heritage vacuum
it's most likey it's the belt that needs replaceing witch is very tricky to do this video will give you full instructions how to change it.
Nov 10, 2012 | Vacuums
My oreck vacuum has stopped sucking up things.
It won't turn the brush because the belt is stretched or broke from the heat of sucking something too big up. If you have your service manual it should show you the location of the belt covers to replace it.
Dec 03, 2009 | Montgomery Ward Oreck XL Celoc...
It is working but I dont see it cleaning nothing is turning around when it is sucking
If the roller brush is not turning then that means that the belt is either worn, stretched or broken. You need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 18, 2009 | Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Brushes wont turn, therefore not sucking up dirt
Check to see if you have a broken belt which is connected to brushes to make them turn.
Sep 13, 2009 | Vacuums
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
109 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
