Question about Cosco Baby Gear
Put the croutch belt back on a cosco highback 22233-pdp
I just bought a used car seat and took all the belts off to was the cover and the seat before I was going to use it. Now I don't remember how to reinstall the crotch belt.
How do you put the cover and straps back on the carseats
We need a model number and date of manufacture. Most Cosco
car seat belts are long and thread thru the bottom first. Then up thru where the childs legs are, into the latch mechanism, up thru the chest clasp and out thru the upper back area. A small anchor mechanism on the back of the seat secures the belt on each side. Some belts are 18" long and there are 2. Use the same procesdure just bring both up thru from the bottom.
If you can post the model # and date of manufacture I can be more specific.
Apr 28, 2012 | Cosco Baby Gear
Need to reassemble belt system
http://www.coscojuvenile.com/usa/eng/Instructions?ProductNumber=22216LLP
Just need to enter manufacture date to get the manual.. The instructions should be in there to reassemble the belt system..
Jul 11, 2010 | Cosco Juvenile Scenera Convertible Car...
I have an eddie bauer HB3C 22-89c-BGL please send
hi i wash he coution of my eddie bauer highback 22-89c-bgl and now im having problem putting the belt togeter in their original place
Sep 28, 2009 | Eddie Bauer Baby Gear
COSCO MODEL#02-444-1PK My mother-in-law bought at a garage sale and there is not an instruction manual - want to make sure it is safe and no recalls.
I am not aware of any recalls for your car seat. The guidline is 5 years from date of manufacture or if there is a dont use after date stamped in the plastic. Belts should be snug over childs shoulders. Seat belt goes thru the back holes midwat down and should be as tight as possible. Most fire stations will help you secure your car seat. Just ask them.
Sep 28, 2009 | Cosco 02-442
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
How do i assemble my cosco car seat
Well.. I really could use some more info about how the carseat looks but thinking todler if it is the largest todler one you should just put the seat belt over the childs arm and waist and buckle regularly. If it is the one with the pull down plastic piece. you run the seat belt through the first side put your hand in the other side get the belt and pull through the last side then buckle.
Please right back and let me know if this helped :)
Oct 29, 2008 | Baby Gear
The belts
did you have the user manual
May 07, 2008 | Cosco High Back Booster 22-200 /22-207
Baby Gear Logo
107 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
thegtw
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
