Question about Lexmark Office Equipment & Supplies
My cyan colour won't print : tried aligning page, everything, can you help?
Tried everything , new ink cartridges , aligning, print test page and same thing happens
  • Official Brand Answer
  • 3,344 Answers
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Posted on Feb 14, 2012
  • 84 Answers
SOURCE: have replaced black ink twice,
Well I dont know if this will fix your problem but it worked for me.
I removed my ink cartrage put it in a printer exact same modle and put it back in.
Printed with out an issue. however the only problem is you need 2 printers. :( have a friend that may have the same one?
Posted on Aug 18, 2009
usmanfz150
SOURCE: Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
Posted on May 08, 2009
graemevm
  • 519 Answers
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Posted on May 07, 2009
  • 355 Answers
SOURCE: epson stylus cx4900 printer not recognising
remove the cartriadge clean the head and try again
Posted on Oct 02, 2009
  • 3278 Answers
SOURCE: won't print blue, print head alignment failure, hp
Hello, Kim.
Here's some help from HP regarding your problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01078810&cc=us&lc=en&dlc=en&product=3204785
Hope this resolves your problem.
Posted on Dec 02, 2010
Can Dell A960 ink cartridges be refilled and re-used or not?
A lot of inkjet printer manufacturers make you purchase their ink cartridges by installing a chip in the cartridges so when the cartridge is empty it cannot be reused by filling the cartridge.
Jan 28, 2013 | Dell A960 All-In-One InkJet Printer
My HP Officejet Pro K550 is not printing the cyan (blue) ink. It has a new cartridge. I've run print quality pages and configuration pages -- no cyan shows up. I cleaned the printheads and no c
Do a test print...
assuming you have done multiple print head cleans... if it fails to print ANY cyan, I'd guess the print head is dead... although to be honest im not an expert with this hp printer. if that is the case, it probably isnt worth repairing.
If it does print some cyan, just missing, you may be able to find info, sorry, I cant help you there, on accessing the service or maintenance mode and doing a higher level clean, if your printer supports that.
As a last option, disassembly and soaking the bottom of the print head in cleaning solution /water... overnight, without getting ANY water on any contacts, then re running print cleans.
good luck
in my exp, again, not with this printer, mind you, if a print head fails to print ANY ink for a given colour, the print head is usually faulty.
Hope this info helps
May 15, 2012 | HP OfficeJet Pro k550 Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
I cannot get my printer to print. I have black ink and all other colours except cyan. I want to print in black and white but it won't work, please help
Hi there!
In order for you to print you need to refill your cyan ink cartridge. Even if you just want to print black and white.
May 08, 2011 | Office Equipment & Supplies
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
I am having a problem printing with my HP printer
you wasted your time using cleaning program and heaps of ink...
follow this procedure:
1. remove all ink cartridges from the printer
2. check if ink is soluble in water, isopropyl alcohol or methylated spirit (this which do not create lumps or precipitations is correct solvent)
3. put one drop of solvent in th centre of aspiration hole on receptable
4. if solvent is absorbed through input, that meant problem is not with printer but with cartridges.
5. check printer cartridge by stamping them with tissue if they "produce" any ink on the outlet,
6. put one drop of solvent on cartridge outlet and insert them in correct bases
7. print test page, print should be rather weak as solvent will go through the nozzles
8. print test page from computer
9.create "strip page" of each colour used, separate by no colour (white) start with yellow strip, then white, light cyan, white, cyan, white, light magenta, white, magenta, white, black - this strip pattern will force all cartridge to operate on they max delivery.
if there is no result, service by technician will be in place...
all ink based printers need to print at least one page per week... ink will dry pretty fast, especially in dry or hot condition.
Jul 28, 2010 | HP C6250 InkJet Printer
Wont print cyan
Install the correct driver for your system.
Find them here:
http://software.canon-europe.com/
I searched this for you. Pls leave a good rating!
Oct 11, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Put in new ink and it is telling me out of ink and will not let me print anythings.. How do you reset ink
Simple oly when you know how ;-)
I think you have a slight blockage, to solve:- (dont know which printer or PCyou have so ill do my best)
Click on Start
All programms
Pick your printer from the list
Open the software
You will have 2,3 or 4 options depending on your printer spec.
You need to 1st remove the cartridge
Print 1 page with no INK a message will pop up saying con not print need ink for example.
You then NEED to calibrate your cartridge, you need to find:-
1 Align Cartridge/Nozzle - Unblocks, and Sets up. (Syncronize)
2 Calibrate Black - unblock black
2 Calibrate Colour - unblock colours
3 Print test Page - See how it looks
5 Align again - Unblocks everything giving good ink flow and gets the print right close to 100%
6 print test page!
It shoud now work ;-)
Good Luck xxx
Jul 15, 2009 | Canon Pixma MP480 All-In-One InkJet...
Eratic printing of colour pages
probably needs an alignment test as well as a colour check.
Failing that try using a new ink cartridge.
Hope this helps
Feb 14, 2008 | Computers & Internet
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
