Question about Canon imageCLASS D320 All-In-One Laser Printer
Need driver for canon image class D300 for mac osX
ohms
  • 1879 Answers
SOURCE: I need a printer driver
http://www.fixya.com/support/r1468656-free_printer_drivers_lost_driver
Posted on Sep 03, 2009
  • 628 Answers
SOURCE: canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Posted on Dec 10, 2008
  • 523 Answers
SOURCE: I need to find a driver that works for the Canon
go to the webpage canon.usa.com and then go to download and choose your machine, the driver will be there.
Posted on Mar 19, 2009
marked
  • 6487 Answers
SOURCE: Drivers
You can download the vista driver for this unit from this link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=12943#DownloadDetailAct
Posted on May 11, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
Cant add Canon Image Class MF4350 laser printer to my Mac
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Nov 27, 2012 | Office Equipment & Supplies
Where can i find a mac scanner driver for canon image class mf4270 canon drivers don't support mac
You need to download the drivers for your canon on mac Go to this link: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4270#DriversAndSoftware When you get there, select scroll down and select Then where you see "Operating System", select your operating system will then show all the drivers for your operating system scroll down until you see the driver software and then download and reinstall it. Hopefully this will help...good luck.
Oct 23, 2011 | Office Equipment & Supplies
Can I load the driver/software for my canon MP210 printer onto my OS Macbook pro?
Yes you can but you'll need to install the Mac OsX driver to make it run through your Macbook Pro. You can download the Mac OSX driver from HERE,(open the link and select O.S i.e. Mac OSX and Language and click "submit", the download links will be displayed) it should also be included in the CD that came with the printer.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jul 06, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Is there a Canoscan D2400 driver for Mac OSX 10.6 available?
Access the manufacturer's web-site:
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d2400uf
and click "specifications" -- there's some mention of support for various versions of Mac OS.
Does OSX 10.6 have "built-in" support, i.e., device-drivers are included, without needing any downloads from Canon's web-site?
Oct 20, 2010 | Canon CanoScan D2400UF Flatbed Scanner
Since upgrading to Mac OSX Leopard the scanner does not work, how can i fix this?
For Mac OSX 10.6, there are very few Twain drivers built in.
You have to download the Twain drivers compatible with Mac 10.6, installing previous versions of the Twain drivers can cause repercussions for the Mac.
Canon should have updated drivers on their website.
Mar 25, 2010 | Canon Pixma MP800 All-In-One InkJet...
Canon Image Runner 2200 cannot print with Apple Snow Leopard 10.6 OS because Canon has not come up with the new driver
I'm not that familiar with Mac but I did notice that they (canonusa.com) did release a Mac os9 & OSx update driver on Oct 20th 2009, but other than that ....
Dec 17, 2009 | Office Equipment & Supplies
IR C320N scaning with MAC OSX
Use the Irc 3200 drivers on the Canon USA
Color imageRUNNER C3200 : Drivers & Downloads
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=8927
Feb 08, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200N scan with MAC OSX
Hi!
Please download the drivers from the Canon Website.
Please rate this solution if you find this solution helpful.
Thanks
Rylee
Printing from my macbook pro using my Canon Image Class D320 I recently purchased a MacBook Pro and I'd like to print using my Image Class D320. I see no support and no drivers out there. Any...
I am sorry but some companies do not have Mac drivers for the older devices. You can try downloading the SWITCH ( not sure of the correct name) program that lets you run a make shift ( simulation) windows on your Mac and that may be the way to print to this device.
Jan 04, 2009 | Canon imageCLASS D320 Digital Copier
Canon imageCLASS D320 All-In-One Laser Printer Logo
564 people viewed this question
old marine
old marine
