Question about Tools & Hardware - Others
Please help!!! Fan running continuously
Fan continuously runs in all modes unless breaker is flipped. Replaced relay and thermostat. Brand new thermostat caught FIRE on the wall at 3 am two days ago. Put old thermostat back on wall and must use breaker to shut off (both new-now burnt-and old thermostats needed breaker to shut off fan). Needless to say we are TERRIFIED to run furnace. What could be the problem keeping fan on continuously? Note: We honestly believe the new thermostat that caught fire was defective.
    Problem Solver:
  • 6 Answers
A lot of furnace control boards turn on your fan run in the event of a blown fuse or lost control device to be sure tgere is air accross the heat exchange. If you correct what ever caused the stat problem. Check your 3 amp fuse on control board you will find it blown?
Hope this helps. Please contact a certified hvac person. Your dealing with your safety
Posted on Jan 05, 2015
    Problem Solver:
  • 7 Answers
Sounds like its wired up wrong
Posted on Feb 11, 2012
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
Jun 07, 2016 | Intertherm Heating & Cooling
HOW TO FIND THE CAUSE OF THE BLOWER RUNNING CONTINUOUS
Model of fan? Oscillating? Near heat source , more detail and you may get an answer
Jan 08, 2015 | Heating & Cooling
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Coleman Rooftop AC fan stops after 7 or 8 minutes of running. Will turn on again after about 10 minutes on its own.
Remove green (fan run) wire from thermostat, and connect to red wire (power) and see if fan runs, and if it will stay running. That will by-pass thermostat to see if it is problem. If it continues to run, thermostat is problem. If that doesn't cure it, I'd remove cover up top and with power off at circuit breaker, blow compressed air in to motor air holes to make sure it's getting proper air for cooling, as well look for small plastic plug on housing where oil can be added ( few drops) to lubricate motor. Leave cover off and try fan to see if that may help. If at all possible, a clamp on amp meter will confirm if motor or relay is at fault if none of these suggestions help. If amp draw at motor too much, motor may be seizing when warmed up from running. test draw when first started and after running for amount of time that it usually quits, and if noticeable difference, motor is seizing and needs replace. You can also test amp draw at main 120v feed wiring with unit just in fan mode.
Sep 13, 2012 | Coleman Heating & Cooling
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
My fan outside will not turn off. I have a Ruud Achiever 10 unit. I cleaned the coils on the unit outside and the filter for the furnace. The unit does cool.
Is the compressor also running or just the fan? If both are running, you've probably got a freon leak and the system isn't cooling properly so it runs continuously trying to reach the thermostat set-point.
If only the fan is stuck on, you've most likely got a stuck fan relay. Replacements are available at HVAC supply stores and most will sell to the public. Not a real difficult fix but BE SURE to pull the electical disconnect AND flip the breaker OFF before you attempt any repairs.
Jun 11, 2009 | Ruud Matching Split Air Conditioner
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Tools & Hardware - Others Logo
94 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
