LG 26LX1D. Has worked for 2 years. Recently moved but the day I left I was still watching the TV and then wrapped it in a thinks blanket for protection and placed it ontop of several winter coats for more protection, screen side up. Nothing placed on top of it. No jars or crazy stops. Whn I plugged it in with the first cord at my new destination, no red LED that usually comes on to show that power is getting there. Tried 2 more cords, 5 outlets and two surge protectors. Finally I get a faint constaint red LED blinking, but now power up, no atempt to power up, nothing but the blink. took back off and looked for bulged capacitors, all are totally flat. No burn marks on any board to suggest a short. Everything looks as it should. I have had in the past needed to clean the fan but at the time the red LED was strong and would blink the green LED and not fire up until I aired the dust off the fan. THis isnt even getting to that. please help so I don't have to get a new TV. I don't fancy replacing capacitors if i dont have to and none lok bad. I am dumbfounded b/c nothing really happened to the TV except no use for 5 days. it was surrounded by cushion and nothing on top of it. I dont get it.
  • 3,866 Answers
It's possiable the powerboard is just not filling those cap's to capacity, this would explain why the green light does not come on, also what can be possiable is a relay in the power board that is not passing the 110v. I am uncertain of cause.. However 5days would drain the capictors to a point where the refilling process failed. I am just wondering if it got could in the structure? IF so how cold. Eletronics only can handle a certain temp.
I would say power board.
Posted on Feb 13, 2012
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
LG LCD 26LX1D power blinking red ,all capacitor on power board are ok
try replacing relay on power supply had this twice on lg and goodman lcd tvs
Nov 25, 2012 | LG 26LX1D 26 in. LCD HDTV
I have an lg 26lx1d tv, suddenly red light bottom of screen was gone and then wouldn't turn power on.
  • Jeramie 36 solutionsMar 23, 2011
Replace capacitors c520 and c126 to get your power working again.
Also make sure that you don't have a broken green 3 inch jumper wire broke that lies under the heat shield in the top right corner. The wire should be glued to the board for stability. It sometimes breaks loose and will cause the TV screen to stay off.
Aug 28, 2012 | LG 26LX1D 26 in. LCD HDTV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
LG 26lx1d tv will not turn on. Power supply is fine. Remote control is working. Also tried on/off button on tv and tv does not turn on. Red light blinking on front bottom of tv near remote receiver.
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Jan 24, 2010 | LG 26LX1D 26 in. LCD HDTV
LG 26LX1D won't turn on.
My LG 26LX1D is the UA Version.
The solution for my problem was unclogging the Small Fan by the Main Panel, on the opposite side of the TV as the Power Board.
This is My Story.
The TV I found at the dump seemed good, but would not turn on.
Two LED's showed up on the front panel of the Television. First, the Red LED (on, off), then the Green LED (ON), then the Red LED (blinked) while the Green was still on.
I removed the back panel and saw that there were NO SIGNS OF BAD CAPACITORS on the Power Board. I plugged in the TV once more to see what would happen.
I noticed that there was a SMALL FAN which did not move when I plugged the power source to the outlet. This Fan was CLOGGED WITH DIRT.
I unscrewed the Fan from it's place and set it on a dish to act as a buffer against the main board. I then proceeded to clean it with a Vacuum Cleaner and a small Flathead Screwdriver.
I now own a FUNCTIONING LG 26LX1D-UA, RESSURRECTED!
Dec 31, 2009 | LG 26LX1D 26 in. LCD HDTV
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
I need to buy Powerboard for 26" LG LCD Television 26LX1D
There u go .!!
http://cgi.ebay.com/LG-Electronics%2FZenith-6871TPT303B-PCB---POWER-BOARD_W0QQitemZ390119483627QQcmdZViewItemQQimsxZ20091117?IMSfp=TL091117189007r1099
This product works with the following models:
LG Electronics/Zenith 26LX1D
LG Electronics/Zenith 26LX1D-U
LG Electronics/Zenith 32LP1D-UA
LG Electronics/Zenith 32LX1D
LG Electronics/Zenith 32LX1DUA
LG Electronics/Zenith 32LX3DCS-UA
LG Electronics/Zenith 32LX3DC-UA
LG Electronics/Zenith 32LX4DCS-UB
Nov 24, 2009 | LG 26LX1D 26 in. LCD HDTV
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
I recently moved my toshiba 62mx195 across country it was well wrapped in bubble wrap and moving blankets, Now we go to turn it on and nuthinghappens except the timer/rec blinks yellow then the power blue...
Your Tv power supply is in protection, this means it wont start up, could be static. Rather take this to a Service Centre to check, If you have insurance claim it under the section travel/moving goods etc
Dec 05, 2008 | Toshiba 62MX195 62" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
