Question about Gateway DX4200-09 PC Desktop
Reset video setting in bios dx4200-09
Screwed up bios setting for video. How or can I get back to factory setting
  • bill clements Feb 11, 2012
    Solvedit.... Pulled xmas battery
Factory rest
To reset, pull the battery out so the BIOS discharge. There are two pins that are bridged with a small black connector. Three Pins are visible and you need to lift the bridge connector from the two pins they are now on, move it to the next two pins. That removes the BIOs data sequence currently active and brings the BIOs back to Factory settings. In some cases, OLD Bios need an Update from the manufacturer. Once the factory reset is done, put the connector back on the original pins, fire up the computer and start from there.
Jan 18, 2015 | Computers & Internet
Want to restore to factory settings
Which factory settings? If you mean the BIOS settings, when you start the machine, go into setup (could be F2, F11 or F12 depends on the motherboard) and there is a place in there (you'll see it when the screen opens) to reset to default. It will ask if you really want to do it, answer YES and it will reset all of your BIOS setting back to factory defaults. Once it resets, it will reboot the machine.
Nov 05, 2013 | Acer Veriton M261 PC Desktop
I need to reset the Bios password. I cannot reset the bios to the original settings. what jumper is used for this job and how exactally is ist done ? I've never done this and have been told that it is the...
To reset the BIOS back to the default settings and you cannot locate the reset jumper, just remove the BIOS battery for approx. 30 mins.
This will discharge the battery voltage in the BIOS, then insert the BIOS battery back and you can go into the BIOS configuration and set the Date and Time etc.
Jan 26, 2011 | DFI AK75-EC Motherboard
Netbook fails to boot up. Black screen after samsung logo.
I had the same problem today - Samsung updated some of its software last night, then this morning the netbook couldn't boot.
I entered the BIOS - press F2 - and told the BIOS to reset back to its default settings. This fixed it. I guess the update screwed up the BIOS somehow.
Oct 18, 2010 | Samsung Computers & Internet
How to i get my amd turion 64 x2 tl-50 to factory reset?
You can reset your BIOS to factory default. There is an option there. Or you may only change the settings about CPU to the default or automatic.
Aug 18, 2010 | AMD Turion 64 X2 TL-50
How can i unlock dell latitude d420 bios password i bought the laptop at auction, now i'm screwed.
For that try password as "dell" or "DELL"
If it not works then you have to reset all settings of bios to factory defaults.
For that you need to open back side cover of laptop.
Open all screw in back side then remove cover then you find motherbord chipset .
Pull cmos cell from motherbord 15 minutes so all settings goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 16, 2009 | Dell Latitude D620 Notebook
How do I reset bios on emachine d3415
When you say reset...do you mean that you want to restore the bios back to their original factory settings?
That can usually be done from the bios (reboot, press either F2 or F10...the screen that displays upon boot will let you know what to press) ...there should be an option to re-set the bios back to the factory settings.....
But if that is not wat you are trying to do, let me know.
May 08, 2009 | E-Machines eMachines Desktop PC
I nedd my laptop
If you lost you password to your BIOS, you can reset your BIOS by taking out the CMOS battery and placing it back in.
On the bottom of your laptop, you should see a panel that is screwed on. Take out the screws, and in there should be your hard drive, or your laptops memory sticks. And around it should be a round battery connected to the motherboard with a wire. Un-plug and Re-plug the wire, and your BIOS should have reset back to its default settings.
Dec 27, 2008 | Computers & Internet
Re: HP Pavilion m9150f - Need hardware solution for bios reset
just restart ur bias...by just reinsert the battery in motherboard...but it lead u to delete all ur datas in it...
Oct 27, 2008 | Computers & Internet
How to reset my compaq computer back to the factory setting
Reset your operating system software (Windows XP..)to Compaq factory setting : restarting your computer. Hold down F10 key, your computer will go into recovery software provided windows recovery was preloaded into your hard disk during installation.
Follow on screen instruction.
If it your Bios you want to restore to factory setting, restarting your computer hold F1 key, entering BIOS set up. Look and press the key assigned "Default Loading" save change and exit Bios set up.
Does that solve your curiosity
Jul 27, 2008 | Computers & Internet
Gateway DX4200-09 PC Desktop Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
