Question about Maytag Kitchen Ranges
I have a Maytag MGR5720 ADH gas range. About a week ago it started making this horrible noise only when the oven is on. The only thing I can describe this noise as, it is as if there is a smoke alarm going off in another room or basement, the sounds is muffled, but it is constant, not just a continuous beeping sound. It will happen on and off during the whole time I am cooking and is rather loud. I tried looking in the manual, but did not see anything related to that. I would just love to solve this problem before I need to cook for 3 days right before and on Thanksgiving, that way if I need to get a new stove, I will have plenty of time. By the way, I did try to unplug it for like 10 minutes when it was off and plugged it back in, the next day I turned on the oven to make brownies and it was still happening. I am at a complete loss and really just want it to stop.
fridgetech
  • 473 Answers
SOURCE: No spark on all burners, oven doesn't work either
Give me the complete model # from the sticker on the oven and I will try to help.
Posted on Nov 07, 2007
  • 7 Answers
SOURCE: F1 and F2
depends on the brand, most of the time its an erc (electronic range control) this can be replaced. find a appliance store near you, give them the model and ask for the price and availability of an erc. If satisfied call a tech. If a tech installs it you have a warranty... get the picture?
Posted on Feb 09, 2008
  • 6 Answers
SOURCE: Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Posted on Sep 25, 2008
  • 13 Answers
SOURCE: gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
Posted on Nov 30, 2008
leecom72
  • 4806 Answers
SOURCE: Laptop makes horrible beep sound when plugging in power cord!
Many laptops do this and there is nothing wrong but it can be annoying and in most cases nothing can be done about it apart from going into the BIOS and seeing if you can disable it.
Regards.
Posted on Aug 18, 2009
Testimonial: "Thanks for the quick response!"
When oven was 1-year old, the lower oven started making a noise that sounded like a blow torch, usually after being on for a little while. It was (after many service calls) repaired by replacing the...
Hi Nancy
I have to ask you a couple of questions. Is the range set up for LP or Natural gas? Blow-tourch sounds are normally caused by to much air going into the burner. If you can look at the burner safely the flames should burn just out of the burner. If the flames are way off the burner the air adjustment is way off or you range is set for the wrong gas. Are your top burners OK?
Sep 13, 2010 | Maytag Kitchen Ranges
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
Squeaky oven door
Put a few drops of WD 40 oil on the hinges supporting the oven door
Nov 28, 2009 | Maytag MER5752BAW / MER5752BAQ /...
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
Whirlpool RF368LXMQ Overheats; Displays F3E2
I'd start with testing the oven sensor that if that is bad it wont be horrible because you'll have no problem replacing it yourself less than $100. That is where I'd start let me know if it works. Good Luck.
Diane
Jan 16, 2009 | Whirlpool RF365 Electric Kitchen Range
How do I find the control board in a Maytag MER5755QAQ range?
you have to pull the stove out from the wall. There is a plate on the back that you have to take off and it will expose the clock.
Dec 11, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag Gemini Electric Kitchen Range
Codes are correct .The back needs to be removed and your sensor is a 2 wire part ,The easiest way to make sure you change the right one is by turning oven to on and run a voltage test at each end of the thermostat.Rule follows : If oven is on you should have 115 -120 volts present and make sure you have the same at the other end of thermostat ,if you have the volts at one side and not the other than that is the bad thermostat. Please rate this !
Aug 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Have Ilve oven but have misplaced the manual and we need to know the self cleaning program instructions
Here's the user manual for the Following Maytag Range Models (It covers MGR5710 • MGR5720 • MGR5729 • MGR5730 • MGR5755 • MGR5750) =>
http://shared.whirlpoolcorp.com/assets/pdfs/literature/MGR5710ADQ.PDF
Aug 10, 2008 | Maytag MGR5750 Gas Kitchen Range
Maytag Gas range
We had the same thing happen and had the Atco Gas company come out to look at it.  Our regulator was not working properly which caused CO to be relased.  We were told that the problem could be fixed for about $250-300 (CAN.) including parts and labour.
Jun 09, 2007 | Maytag MGS5870 Gas Kitchen Range
Kitchen Ranges Logo
62 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
