Question about Exercise & Fitness
Treadmill owners manual for a tempo 632T treadmill
How do i lube my treadmill. it is now asking me to do this and stops, continually.
Posted on Aug 08, 2013
Error message E1 on tempo 632t treadmill - what is it and how can I fix it ?
Hi There,
Tempo....check this lower control board for a small potentiometer or little square cube with a screwdriver slot in the top. Adjust this pot CW to 3/4 full turn and retry. Check feedback sensor(s). Does the belt move and then error and stop, or never start? These lower boards do fail and you can contact jatinah@rocketmail.com for more help if needed. Good Luck
Apr 11, 2017 | Exercise & Fitness
My treadmill has gotten stuck in the highest incline position??
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 21, 2016 | Tempo Fitness Model No. 632T
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
How to lube belt for Tempo 632T treadmill
Do not use wd-40 on your bearings. That will only clean it and dilute the bearing grease that came with it from the manufacturer, thus hindering it's longevity. Axle/bearing grease is the only solution here. And as mentioned, 100% silicone lube between the belt and deck. Ensure to properly tension the belt so it does not let the roller slip, while in use, and possibly burn the belt.
Enjoy!
Aug 05, 2013 | Exercise & Fitness
E2 error code on my Tempo 612T treadmill
adjust and clean the speed sensor, and tight the connector very well, see the diagram
2) test the input voltage motor, if there are voltage the motor replace
3) test the output voltage board, if there are NOT voltage , the board is faulty, replace.
God bless you
Nov 11, 2012 | Exercise & Fitness
Need owners manual for a tempo 632T treadmill
Says to lube belt did that but still saying lube belt. Won't run when the safety key is put in
Feb 20, 2012 | Life Fitness Exercise & Fitness
I need a key for my tempo 920t please help
I have looked all over online for you and there isn't a place that directly sells the replacement keys. However you can call Tempo Fitness directly and have them send you a key, you may need to purchase it from them, but as you are probably aware you need the key to get the machine to function, so you definitely need the key. Give Tempo a call at 1-866-99-Tempo, they are only open 8 AM to 5 PM Central Time though, so you will need to call tomorrow.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 19, 2010 | Horizon Fitness Tempo Fitness Treadmill...
1984 Ford Tempo no owner's manual
I could not locate a down loadable owners manual
there are several service manuals on Ebay book4cars.com has one for $14.95, yu should also check local salvage yards near you for one.
Jul 19, 2009 | 1984 Ford Tempo
Exercise & Fitness Logo
965 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
