Question about Karcher K 593 M Electric Pressure Washer
How to disassemble a karcher k9000 pressure washer
5 Suggested Answers
  • 92 Answers
SOURCE: trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Posted on Nov 19, 2008
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 5 Answers
SOURCE: karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Posted on Jul 08, 2009
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
How do I change the oil
I assume you are talking about the pump. Not good, remove
pump, disassemble and oil falls out. Put in new oil upside down
and reassemble pump, then reinstall.
Oct 06, 2012 | Karcher G 2600 VH Gas Pressure Washer
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
Where is the unloader valve on my pressure washer
is not necessarily a cap, but could be a screw in plug, that should be close to the hose hook-up on the pump Inside there there should be a round ball and a spring that you can tighten or loosen to adjust the unloader and if it has been used ALOT, where the ball seats there could be grooves cut in there and you might need to get a valve kit to fix it
Sep 05, 2009 | Karcher 2500 PSI Pressure Washer
How do i release the pressure when the unloader valve is stuck
Start by removing the garden hose. Now you must CAREFULLY unscrew the high pressure hose and it may be necessary to use vice grips.DO NOT attempt to disassemble any of the pump when it is in high pressure.
Jul 14, 2009 | Karcher Garden
Cycles, never builds up full pressure when trigger pulled
If you are sure it is not a bad o-ring and you have re-assembled it correctly then try this.
Visit here:
http://www.rjbowers.com/parts_manuals/partslist_1190343804.pdf
Part # 8 in the pump, karcher # 9.001-187.0 includes a small bullet shaped valve. It could be leaking. It can be carefully disassembled and cleaned.
Jun 13, 2009 | Karcher K2.26 Electric Power Washer
Need to reset and adjust downloader.
Hello sir, please if you know how can reset service intrval for KARCHER HDS 10/20M year 2009.Thank you .
Apr 09, 2009 | Garden
No pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Jun 22, 2008 | Karcher 2500 PSI Pressure Washer
Karcher K 593 M Electric Pressure Washer Logo
163 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
