Question about Panasonic CT-30WX54 30" TV
How do I change resolution in Panasonic TV Service menu?
I know how to access the service menu and such, and I can change the screen settings in 420i, but I have no clue how to change the highlighted (red) 420i to the 420p option or the 1080i option. What I want to do it switch it to 1080i and edit the width of the screen. All I can do right now it edit the width of the 420i setting, seeing that I dont know how to change the resolution.
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
SOURCE: Convergence problem on rear projection Panasonic PT53WX42?
Chris Palmer gives detailed instruction on how to replace the convergence IC's. Go to his blog at: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Sep 26, 2007
SOURCE: Panasonic TV 50 inch plasma
I had the same problem and found that I was viewing the TV input instead of the composite input. Once I changed it back, the aspect setting would hold.
Posted on Feb 10, 2008
  • 4 Answers
SOURCE: panasonic viera not fitting screen - 32"
The problem was with the cable/sky decoder. I changed the aspect ratio on the decoder not the tv.
The TV was not the problem.
The problem is that the decoder is sending a 4:3
picture to the tv this needs to be changed to 16:9 in the set up menu on
the decoder.
Posted on Sep 27, 2008
SOURCE: Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Posted on Feb 21, 2009
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
The picture does not fit the screen
Resolution is set too high on the TV. On the TV remote open Menu
Go to set up
Change the screen resolution to the next one down.
Mar 27, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
For a Panasonic CT-30WX54J: What's the button sequence to do a factory restore of the settings in the 'Service Menu'.
Press and hold Power & Chnnel button on the front panel of the TV, and plug it to AC power. The set must come on with service mode screen. The procedure will differ set to set. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | Televison & Video
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
May 11, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
How can i access the service menu of panasonic tv tx-42lz80m?
Pansonic Limits access to prevent you from making any irreversible changes to the settings or firmware.
What are you trying to do?
Panasonic TV Repair Denver Service
Jan 27, 2011 | Panasonic TCP50S2 50 in. TV
My insignia NS-L26Q-10A 26" LCD television is showing that it is 420i on the screen and I understand that it is supposed to be 720p. How do I change this?
This may have to do with the settings on your DVD player or cable/satellite box. Change the settings on those devices to output the desired resolution (720p) and adjust your TV settings appropriately. More details about the TV settings can be found in the owner's manual.
Dec 29, 2009 | Insignia NS-L26Q-10A 26 in. LCD TV
Picture to large on Windscreen TV to see Menu from PC
First try changing the screen mode on ur TV, FULL/ZOOM/WIDE. If not then try changing the desk resolution on ur PC to the same resolution ur TV is. to be save just change it to 800X600. If that wrks then look in ur manual or right the bos it cam in, shld say what the TV max resolution is.
Nov 21, 2009 | Dell Dimension 4550 PC Desktop
Using HDMI : PC - TV picture isn't clear?
Check the resolution you have that port (monitor) set to. Most likely you have it set at a resolution that the TV doesn't like, or perhaps it is set at its lowest possible resolution. Just make sure it is set at whatever the highest your TV handles, 1920x1080, 1280x720, etc.
Nov 15, 2009 | Philips TV Tuner Video Capture PCI Card -...
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
May 02, 2009 | Televison & Video
Panasonic CT-30WX54 30" TV Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
