So I do to have a TRUCTECH 26 LCD that has no picture but it gets electricity (red light) when I press power it disappears, and still no picture. No green light either. I've been reading the trouble shooting ?'s here and have a few more ?'s. My dad is a kinda familiar with LCD's he wants to know the scamatics of this TV. I see your link where to purchase the capacitors is it still the same? Thanks for your help!
I don't have the schematics,and from what I have read,no one else seems to have them,or can get them either.All I did was replace all of the capacitors that had either the top,or bottom bulged out,and it fixed the TV.The link to the capacitors is a general link.You will have to see what is bad in your TV.When you do go to replace them,you can get ones with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF,and a 16V 1000 UF,you can replace them both with 16V 1000UF,and it will work perfect.You can also use different heights as well,as long as there is enough room.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Does anyone have the part number for a Power Supply for a trutech PLV16260 Television. many thanks...
(More)
Does anyone have the part number for a Power Supply for a trutech PLV16260 Television. many thanks howard
Hi, I'm attempting to set up my RCN remote cable to my Trutech TV, but am having absolutely no luck...
(More)
Hi, I'm attempting to set up my RCN remote cable to my Trutech TV, but am having absolutely no luck whatsoever. Any suggestions?
No picture on screen sound works fine any suggestions or just junk it - is an under the cabinet...
(More)
No picture on screen sound works fine any suggestions or just junk it - is an under the cabinet model used in our kitchen
