Question about Daewoo Televison & Video
I have a daewoo tv and am seeing a same picture split screen how do i fix this
    Top Expert:
  • Daewoo Master
  • 74,383 Answers
Hello
If the picture is spitted to two ahves [Left & Right], the fault is with its horizontal oscillator section. If it is spitted to [bottom and top], ie, you see mustipile image along with a horizontal bar at the center of the screen, the fault is with vertical output or oscillator section.. You must have through knoledge in electronics to do the repair by yoursef at home. Anyway, the internal circuit board should be taken out for repair. OK>
Posted on Feb 11, 2012
PANASONIC PLASMA TV TH-37PD25
did you check into the settings on the cable box and the tv? make sure you dont have a side by side or picture in picture function that was accidentally hit. and since you said on a game system everything is fine, i would check into the settings on the cable box. is the picture the same in both panels?
Aug 14, 2012 | Panasonic Televison & Video
Split screen
either you have the PIP engaged (two different pictures) or if same picture twice a digital issue in the set.
Look for PIP and turn it off or if a swap button see if it swaps the pictures--will tell you if PIP is issue or not.
Jun 07, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
I have a Daewoo 52 flat screen the tv went out
Does the menu come up. If so check to see what input you are on.
Mar 31, 2009 | Daewoo DTQ-13P2FC 13" TV
My Daewoo TV is showing a yellow tinted screen...
this problem actually come from crt socket ic board (just patch behind the picture tube) need to properly clean and resolder back the joint please consult with your tv repairer and i think it not cost much
Mar 24, 2009 | Daewoo DTQ-19P2FC 19" TV
Resetting HD
i HAVE A SONY AND RCA UNI REMOTE BUT CNT GET THE RIGHT CODE
Feb 26, 2009 | Daewoo DTQ-20U4SC 20" TV
The picture on my Daewoo DTQ-25S3FC is stretched
bad electrolytic capacitors vertical circuit. need tech.  not worth repair. guess100.00   not easy repair.
Dec 03, 2008 | Daewoo DTQ-25S3FC 25" TV
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Televison & Video Logo
82 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
