Question about Kenwood DNX6140 Car GPS Receiver
Which wire do i use for the amp - Kenwood DNX6140 Car GPS Receiver
On the back it says remote wire it should be blue...use that one... if not u can use ur acc wire as well, it turns on as sooon as the key is switched on, n turns off in the same manner
Posted on Dec 24, 2012
96, ford mustang, after market radio installation help! where to plug the amp remote wire for amp
The blue wire is a triggering wire of a low amp power for Amps or a power antenna. If it draws too much power (gets hot), use a relay for more power directly off the battery.
e,g..2 amp radio output and if the amps need 1.5 amp each that's 3 amp. Need a a relay.
Jul 17, 2017 | Ford Car Audio & Video
How do I wire in a amp meter please
amp meters are wired in series in a power circuit
that is to say cut the wire and attach each end of the wire to the terminals of the amp meter
you have to know the amps in the circuit to get an amp meter large enough to read the current or it will burn out
( a 60 amp meter for a 120 amp power wire is not right)
in that case you can get an amp meter that runs a resistance in the back of the unit and as volts and amps are directly related by reading the voltage drop across the resistance the current (amps) can be read
That allows a small amp meter with a high face reading to be attached to a large current wire 10000 amps etc
you can also get amp meters that have a crab claw clip that goes around the power wire and by reading the flux field voltage converts that to an amp reading without touching the wire ( used by electricians to check current draw in electrical motors etc )
Apr 12, 2017 | Cars & Trucks
Stereo remote wire won't power on amp sony mex
The easiest check is unhook the remote turn on wire from the amp and use a small jump wire to bridge the 12dvc input of the amp and the remote turn on connector of the amp. If the amp powers on there is an issue with the remote turn on connection either a bad wire or bad output. If the amp doesn't turn on there is an issue in the amp wiring or the amp itself.
Nov 26, 2012 | Car Audio & Video
What size wire and how does it hook to thr unit rpkb-036jaz
Look at rating plate on side of unit for Volts, Amps, Watts.
Volts x amps = watts.
If unit is 240Volts, then you need double-pole 240Volt breaker
If unit is 8500 watts at max power, then 8500 watts divided by 240Volts = 35 amps.
What size breaker for 35 amps?
When electricians figure load rating for breakers, they use the 80% rule.
40 amp breaker x 80% = 32 amp safe maximum load for 40 amp breaker. Use 8 gauge wire with 40 amp breaker.
50 amp breaker x 80% = 40 amp safe maximum for 50 amp breaker. I use 6 gauge wire with 50 amp breaker.
60 amp breaker x 80% = 48 amp safe maximum for 60 amp breaker. Again, use 6 gauge wire with 60 amp breaker.
How to connect wires to unit.
First of all, all outdoor HVAC units require power cut off located next to unit.
This lets the mechanic, or service tech turn power off to work on unit, even if the mechanic does not have access to main breaker box.
Next, open unit to see where wires connect.
If unit has wires, then connect both hot wires from 240 breaker to the wires inside unit. Connect bare ground wire to green ground screw.
If unit has terminals. The terminals will be labeled L1 L2. Connect each hot wire from 240Volt breaker to either one of the screw terminals. Then bare ground goes to green ground screw.
Copy following links for basic illustrations connecting wires to terminals, and to breakers, and selecting wire size.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Jul 21, 2012 | Rheem R-410A Complete Split System Heat...
How to hook up the wiring on the crunch 520.5 need to know the gage for power
  • I would go with some good 8 gauge. More than that for this amp would be overkill and a waste. Many people thing thicker wire is better but that is not the case. To thick of wire to the power feed can draw to much power and send the amp into protect mode. Also to thick of wire with an insufficient amount of power can actual hamper the amps true abilities.
  • Use stranded copper wire not solid copper wire for the best results of conductivity.
  • Make sure to run a 50 amp fuse inline with the power wire right off the battery. Amps surge and it is far easier to replace a $1 fuse than components inside your amp.
  • Your ground is best served running to a bolt in the floorboard. Using the same size, style and quality as your power wire is recommended.
  • Your remote wire will connect to the remote wire running from the back of your deck. The remote wire enables your amp to shut off when your deck is shut off. A simple 16 gauge stranded copper wire will suffice for the remote wire.
  • I recommend hooking the speakers up using one speaker per channel. I don't bridge amps really. If you want more power then buy a bigger amp.
  • The AV cords will go from your deck to your amp right to right and left to left.
  • That's the way to wire your amp.
Regards, Tony
Apr 22, 2011 | Crunch P520.5 Car Audio Amplifier
How to hook up an amp to a car
remote turn on wire( blue/white) from stereo to amp. RCAs from stereo ( sub out) to amp. Power wire (fused) from battery to amp. Ground wire from clean, paint free chassis to amp. Speaker wire from amp to speaker. ( simplied version). Do you have an amp kit? All the wires, connectors and the fuse will be included in the amp kit.They are rated for the amps power output; 0,4,8 gauge.
Sep 15, 2010 | JVC KD-G200 CD Player
Have 2 4+4ohm avi sl500 subs how do i wire it to this amp and what setings on this amp alpine mdr m1005 1000watt amp
using these subs will limit you to a 4 oh load to the amp witch will only let the amp produce half of it's power. the lowest ohm load that amp can handle is 2 ohm and the next lowest you can wire the subs is 1 ohm and that will over heat the amp and destroy it. so to answer your question first wire each sub like this diagram shows...
Wiring Option #1
then once both subs are wired this way you wire both positives from each sub to the positive side of the amps speakers terminals and wire each subs neg. to the amps neg speakers terminal. the wire is series parrelle and will present a 4 ohm load witch will be the safest to run with your amp.
Jan 19, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
What wires do i need to hook up 2 kicker solobaric s15l7 to a car
You will need the amp wires. Red Positive to battery, Black negative from amp ground to unpainted car body surface, and the blue remote wire that goes from amp to remote wire on back of cd deck.
Then you will need the rca cables from rear output of cd player to the amp.
Then just the positive and negative wire from speaker to amp. Use Speaker Positive wire to Amp Right Channel Positive
And speaker negative wire to amp Left Channel Legative wire.
That is it.
Nov 17, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
03 impala there is a factory installed amp all speakers. i am trying to find out if i can power another amp 760w pioneer form the amp that is already there? i have already put outputs for my RCA wires. can...
You might not want to do that. The 760W Pioneer amp might require larger wire due to the power consumption of the amp. Most amplifiers require a direct wire from the battery to the amp. The power wire for the factory amp might not require very large wire and if you tie into the power for that amp the fuse could blow and wiring in your car could melt or catch fire, The best installation is to run the recommended guage wire from the battery directly to the amp with a properly rated in-line fuse.
Nov 07, 2009 | 2003 Chevrolet Impala
HOOKING UP 2 AMPS
Ideally you would use 1/0 gauge power and ground wire for the amps, and use power distribution blocks to reduce it to 4-gauge for each amp. Any smaller wire would be less than ideal for that much amp power.
If you're buying a power wire kit, it most likely won't have a separate distribution block for the ground wire (usually they have separate ground wire for each amp or one piece that's long enough to cut and have wire for both). This is fine, but you should look for a kit with at least 3 feet of ground wire per amp - any shorter and it's a struggle to mount the amp close enough to a ground point. As above, the main power wire to the battery should be 1/0 gauge.
Lastly if a 1/0 gauge kit is not available, 2 separate 4 gauge kits will work, however that's obviously a lot more wire to run and conceal.
Feb 21, 2008 | Car Audio & Video
Kenwood DNX6140 Car GPS Receiver Logo
Top Kenwood GPS Experts
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
