SONY STR-DE445 UNLOCK CODE
WHEN I TURN IT ON IT FLASHES UNLOCK OR PROTECT
    Master:
  • 388 Answers
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required.
Posted on Feb 11, 2012
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Posted on Aug 28, 2008
SOURCE: My reciever is flashing the
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Posted on Dec 15, 2008
  • 118 Answers
SOURCE: my sony STR-DE695 flashes protect with nothing
if it is in protection mode with no speakers connected, then youve got an internal problem which will need repaired
Posted on Feb 23, 2010
smarthome2
  • 1114 Answers
SOURCE: Sony STR-D665 receiver display flashes "PROTECT"
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 07, 2010
I need help my sony str dec 445 keep flasking the protect on the display
first check for any loose speaker wire in the back as this will cause the unit to go into protect mode if the bare speaker wire is touching, if thats not the case then there is a problem with the unit internaly and would be hard to tell whats wrong with it without looking at it.
Dec 11, 2009 | Sony STR-DE445 Receiver
DE 445 flashes "protect" and sound goes off when loud noises play on DVD
Check your speaker connections at the back of the receiver and at the speakers. You have a short. If you don't see anything obvious, disconnect your speakers at the receiver and play a dvd and turn up the volume. If it stays on, you have a wire or a speaker problem. If it cuts out , you have a DSP chip problem. Reconnect speakers one by one and test each speaker until it cuts off or you have fixed the problem. If you still have issues, post a comment and I can help you some more.
Aug 07, 2009 | Sony STR-DE445 Receiver
I have a sony str de445 and it overheated one nite and stoped working. when i click the power button it clicks as if it turn on but no display or sound or anything, could you help please
you might have burned up some internal parts, it is very important that you keep your unit well ventalated so that it has less of a chance at overheating, check for any internal fuses that might have blown.
Jun 27, 2009 | Sony STR-DE445 Receiver
Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
Jun 13, 2009 | Sony STR-DE445 Receiver
Trying to use a passive subwoofer with STR-DE445
The output of the Sony is "signal only" not power. Being "passive" like your sub. What you need is a sub amp, and they are not cheap, 400-600 on average "min". Unless you have a Velodyne 15 or 18, just get an amplified sub, they start around 150 new. Hope this helps
Mar 27, 2009 | Sony STR-DE445 Receiver
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
Aug 04, 2008 | Sony STR-DE445 Receiver
237 people viewed this question
 Grubhead
Grubhead
