Question about Electrolux Vacuums
Electrolux Excellio Z 5045 super silence
Red light but won't start vacuuming
  • 694 Answers
SOURCE: Electrolux Super J model, bag light stays on and
Have you checked the screen filter below the bag? This sometimes gets clogged with fuzz and whatnot, resulting in the vacuum shutting off. To clean it simply remove the bag and use a pick or similar item.
A clogged hose will also result in the same problem. Try running without the hose. If the vacuum runs without the hose a blockage in the hose is a probability. However there could be a clog in the power nozzle above the brush, as well. Check the suction at the end of the hose. If very little there's a good possibility this is the problem. Double check by dropping coin in one end and allowing to drop through. If it doesn't there's a clog. It can usually be cleared by plugging the hose into the exhaust port and turning the machine on. Be sure the other end is inside a large plastic bag.
Visually check wands to ensure they're clear. If not, push clog out with a broom stick.
Posted on Jan 16, 2011
mark24354
  • 776 Answers
SOURCE: Bought a used Electrolux canister
My first guess would be that the switch insidet the bag door is not pushed in (or missing).
The cardboard frame around the bag is supposed to push it in when the bag is properly positioned and the bag door is closed. The switch may be missing or loose.
The switch is there to make sure you don't run the vacuum without a bag.
good luck.
-Mark
Posted on May 28, 2011
ercupa190
  • 12223 Answers
SOURCE: electrolux hand turbo vacuum red light troubleshooting
1) Test the main swich is defective
2) Test the belt
3) Tes the motor
Read the instruction manul, if you do not have go www.fitness.manualsonline.com or www retrevo.com
God bless you.
Posted on May 10, 2012
SOURCE: my electrolux twin clean won't turn on
What you might have done is burned out the cable that supplies the power to the actual working of the machine. This happened to be and I had to end up replacing the internal components which took a lot of time, and money. You are better off trying to get a new one and selling this one online for parts.
Posted on Jul 14, 2012
Testimonial: "ty so much .. I will tell my hubby .. it is sad .. I really love this vacuum and I don't handle change well .. ty again .. Debbie "
ercupa190
  • 12223 Answers
SOURCE: Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Posted on Sep 17, 2012
What does it mean when my electrolux 2100 vacuum's protection light is on and the vacumm won't start
hellllllllo.......in short....youtube....."is your electrolux not turning on" [a] bag sensor [b]carbon build up............tkx....g.scott
Sep 25, 2014 | Vacuums
Electrolux ultraactive vacuum won't start
Hi There, The E2 error is caused by the terminal block pins where the hose plugs into the vacuum become bent out of shape. This is the receiving pins at the front of the vacuum on the inside. If what I am saying is confusing then it probably needs to go to a technician, it is a 10 minute job to fix if you have done it before. There is also a slim possibility that you may need a new hose for it too. If you are in Melbourne I can fix it I run the VacuumSpot business.
Jul 06, 2013 | Electrolux Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
Apr 07, 2011 | Electrolux Vacuums
Vacuums Logo
151 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
