Question about Home Security
Can I get a manual
The door doesn't always go up or down and the light blinks on the motor several times. I've changed the battery in the hand pad, still doesn't work.
    Problem Solver:
  • 13 Answers
Do it more.
Posted on Feb 11, 2012
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
My key fob for my 2006 LaCrosse unlocks the doors & opens the trunk, but doesn't lock the doors. Can it be cleaned, or does it need to be replaced?
It is not clear whether the problem is with the fob or the receiver in the car. You could try replacing the fob (they are available online from various sites) but the receiver will need to be programmed to use it, and that usually requires a trip to a dealership (unless you have access to the OEM service manual). Your best bet is to take it to a dealership and have them diagnose and repair the problem.
Jul 05, 2017 | Cars & Trucks
Turn signals in my 98 Toyota Camry don't blink. And the the front passenger window doesn't work. Niether does the car lamp inside the car.
If just one window doesn't work, that is a separate issue, and probably a bad motor for that window. The inner door panel would have to be removed to investigate if it is the motor or a wire not connected.
For the radio and lights, all I could say is check the fuses.
For the blinkers try a new flasher. I've never heard this before, you must be pretty adept at it by now. Wiggling it to make it work means either the connection is poor or the flasher has a foot ******- Replace it!
Jun 17, 2012 | 1998 Toyota Camry
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
My 2001 hyundai santa fe engine revs up and down constantly. It doesn't matter if its in park or while driving. The check engine light has always come on and off. I've had that checked several
Do you have cruise control,see if that cable somehow is giving slack,This is a problem with Hyundai where the cable affects TPS plausibility,There was a TSB bulletin by Hyundai Engine RPM fluctuation - cruise control cable adjustment procedure
Mar 20, 2012 | 2001 Hyundai Santa Fe
My retractable running board on the drivers side of my chevy suburban sometimes won't drop down. You can open and close door several times and it finally will work. The dealership doesn't know how...
I've had numerous issues just this summer with my 2008 LTZ Suburban. The dealership has replaced the battery, some module and, it's back in as we speak to have both runnimg board motors replaced because they both locked up again! A friend of mine owns a 2009 LTZ Suburban and has started having intermittent problems with her running boards, too. When it's time to up-grade, I will NOT be getting retractable running boards again!!
Sep 25, 2011 | 2007 Chevrolet Suburban Three-Quarter-Ton...
Ever since I've had my 2002 trailblazer the back driver's side window won't go up or down. At times the window seems to fall down about an inch or so and I can full with the switch and can...
your window is driven using a cable drive system. kinda like bicycle brake & gearshift cables.
these systems are prone to break. i just wonder why it made noise for so long without breaking.
what you probably need is a window regulator assy.. napa sells them for $191.00 with a new
motor. the hardest part of doing the job is getting the door pannel off without breaking anything
Jun 03, 2011 | 2002 Chevrolet TrailBlazer
Model 2600 diesel tractor-starter motor runs constantly-solenoid is ok-but motor never engages flywheel.
I have the same problem on a gas 2600. Sometimes it engages and sometimes it doesn't. you can replace just the drive end and gear, that's going to be my next shot. I've had the starter off several times and cleaned and inspected it and it "appears" to be working correctly. I even took it to the starter guys we've always used and they found nothing wrong.
Apr 26, 2011 | Ford Tractor Grill 2600 3600 4600 5600...
Home Security Logo
85 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
