Question about Maytag Dryers
Do I have to light a maytag dryer model #MDG7600AWQ?
We just got a brand new gas line installed and have a gas dryer (that was given to us) hooked up. The problem is that no heat is happening. Do we have to "light" gas dryers like a water heater? Thank you for any help!
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Posted on Aug 30, 2009
Illeagle
  • 525 Answers
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
Posted on Sep 23, 2009
I have a LG dryer model dlgx3002w not heating.
It sounds like you didn't install the ignitor properly. Try re installing the ignitor, because it's opening the gas valve saying it's hot enough to light, but if it's out of position, it won't create proper combustion.
Nov 23, 2013 | Maytag Neptune MDG6800 Gas Dryer
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
Our old maytag dryer was hooked up to gas and electricity. we got a new dryer plugged it in and it works but does not heat up. does it need to be hooked up to the gas also?
A gas dryer will have a model number in which the second letter is G as in MGDC
An electric dryer will be ME...
Does that help?
Gary
Sep 04, 2011 | Dryers
Mdg7600awq making a loud noise
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 21, 2011 | Maytag Dryers
My Maytag Bravos dryer is brand new. It is the quiet series 300, but is the loudest dryer I have ever owned. It makes like a loud vibrating, humming noise. Is this normal? I am now drying my second load of...
People, the first words the poster said were that the dryer was "brand new". All of your suggestions assume the dryer had extensive use. This sounds like a factory defect issue!!!! My brand new Maytag Cabrio gas dryer is also making an obnoxious buzzing sound that seems to cycle on and off as the gas ignites. The buzzing sounds electronic not mechanical. What would buzz when the burner is active?
Oct 31, 2010 | Maytag Dryers
Brand new Gas whirlpool duet sport drier will not heat up. Gas line hooked up correctly HELP
Good day,
If it's new, and your sure there is gas in the line to the dryer, then you are entitled to a service call under warranty.
Whirlpool warranties it's dryers for one year from date of purchase.
Call your selling dealer. New one's won't work sometimes.
Dec 31, 2009 | Whirlpool Dryers
Maytag MDG 3000AWW glow bar will not come on. It is brand new
Try checking the gas valve or the thermostat, voltage go'es from the thermostat first then to the gas valve, and from there to the glow bar. Good luck.
Apr 11, 2009 | Kenmore 62602 Electric Dryer
MaytG MODEL MDG7600AWQ
check to make sure the motor is actually running and not stuck, if the motor is stuck and no clothing is around the blower them check the motor to see if it is free, if it is and you turn the dryer on it locks up go get another motor the bearings are worn so that it locks up on start or after running a short time
Dec 27, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
New Maytag gas dryer with long dry times
Double check that vent by finding where it exits your house. It should be blowing pretty hard, like a blow dryer. Guarantee you its a vent issue. Also check that when u push the dryer back against the wall your not crushing the vent. If you have a vent issue. Try sticking a leaf blower in the end that the dryer connects to. Quick fix unless you have a really long vent system. Hope that helps. Dave, www.washermd.com
Dec 15, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
