Question about Neff U1421 Double circotherm Electric Oven
Cleaning the inside of the glass on the oven door
I have somehow managed to get oven cleaner on the inside of the inner glass of the oven door. How do I remove the ginner glass to clean behind it?
  • 1 more comment
  • Anonymous Dec 09, 2007
    I have exactly the same problem. Must be a better answer than this guy gave
  • Anonymous Mar 27, 2014
    serial no 44444o464
  • Anonymous Mar 28, 2014
    How do u remove the inner tub on a 30inch double Electrolux oven It warped when my wife used the cleaning cycly
    New Friend:
  • 163 Answers
Dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Posted on Aug 08, 2006
Need to clean between glass in door how do I do this.
Take the door off and undo the screws that join the outer skin of the door to the inner skin. Inside you will see clips and asbestos insulation that hold the glass in place. You can clean the glass in place with oven cleaner.
Apr 11, 2016 | Ovens
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have cleaned my oven in a house I have just moved into. but I cannot get to the double glass in the door, how do I clean in the middle of both peaces of glass. There are no visable screws or clips like...
this is all i could find out...
How to clean between the glass panes on an oven door:
  1. Remove the access panel or drawer below the oven door.
  2. Attach a moistened glass cleaning wipe to a piece of coat hanger wire.
  3. Slide the wire and cleaning wipe up through the slots in the bottom of the oven door.
More items...
How to Clean Inside the Glass on an Oven Door ' Today's Homeowner..
or go to this link..
how to clean double glass oven door Google Search
Oct 27, 2017 | Caple C203 Electric Single Oven
The inside of my self cleaning smooth top range
Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
Sep 07, 2009 | Ovens
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 | Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Neff U1421 Double circotherm Electric Oven Logo
453 people viewed this question
Top Neff Ovens Experts
Paul Carew
Craig Butler
Craig Butler
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
