Question about Siemens HG2415UC Stainless Steel Gas Kitchen Range
Where does the probe plug into? - Siemens HG2415UC Stainless Steel Gas Kitchen Range
  • merlin101 Feb 11, 2012
    Let me be a little more specific. I do not see a receptacle inside the oven for a temperature probe to plug into. Does this mean my unit has no probe feature?
    Problem Solver:
  • 13 Answers
Plug!
Posted on Feb 11, 2012
Hamilton beach probe slow cooker
Hamilton Beach might be able to advise you regarding proper installation of the probe and, further, can respond if the probe is inserted correctly and still does not respond.
May 19, 2014 | Hamilton Beach 33967 6Quart Slow Cooker
I have a frigidare range and it is flashing F10 and Beeping repeatedly
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Here is the probe to order.
Here is the EOC to order.
Jan 07, 2013 | Frigidaire PLEF398AC Electric Kitchen...
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
Jul 15, 2011 | Frigidaire Ovens
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
Error code F 10 during broiling. model #790.78649601
The first thing to check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
Aug 01, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F 10 code when I try using oven
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
Oven will ask for temp probe when i am not using one. it then turns itself off.
As you did not include a model number I can suggest you insert your meat probe into it's receptacle and remove it again quickly about a half dozen times.....maybe even a dozen times. The meat probe plug is like an older style headphone plug. The receptacle that it plugs into may need to complete a circuit for the electronic control. When the probe is not in the receptacle, the receptacle contacts touch to complete a circuit. These contacts may have become dirty from normal oven usage. You will be cleaning these contacts using the probe as I explained. If that doesn't solve the problem you may want to call in a professional.
May 04, 2009 | Ovens
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
Probe
The jack that the probe plugs into is faulty. There is an internal switch in the plug thats not making contact to tell the unit that the probe isn't installed. Either take it apart and wirenut the two together for the internal switch or replace the plug.
Sep 12, 2007 | KitchenAid KESC307 Electric Kitchen Range
Siemens HG2415UC Stainless Steel Gas Kitchen Range Logo
391 people viewed this question
Top Siemens Kitchen Ranges Experts
Timllfixit
Bill Boyd
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
