Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Stuck ON! trigger is stuck
Simple as that. this drill is a little over 2 years old, and I have to pull the battery to shut it off. it stuck for a second or two the first couple times, and now it's stuck permentantly. Squirted some WD40 around it, did some typical banging on it, tried to futz with the direction switches, the speed, etc. nothing.
  • tyssniffen Oct 27, 2008
    Sorry, good question. The trigger is staying in. Since posting, I have gone to the hardware store and gotten the propert torque wrench bit to take the drill apart, and on first go 'round, it just seemed that there was gunk throughout that was holding it back. I cleaned it somewhat (I was hurried, unfortunately) and it started working - ie popping in and out, turning on and off properly.
    Back on the jobsite today, it started sticking on again. I do intend to go back more slowly and clean it better, but sheesh! I don't seem to see any other problem... and just dust holding the trigger on? that doesn't make sense.
    Tys
  • Stuart
    Stuart May 11, 2010
    is the actual trigger jamming in the machine, or the machine still running when the trigger comes back out?
    Novelist:
  • 99 Answers
The only time I have seen a persistant problem like this before is when there has been a slight defect in the housing or switch. It works ok for a while, and then gets a bit scored up and that is when it usually starts to stick. You could try a bit of emery cloth/fine glass paper on the housing area that the switch button slides through. Also, when cleaning, a good thing to use is brake/carb cleaner as it evapourates quickly and is generally non conductive. It will get rid of a lot of grease, but most switches have a small amount of grease inside to stop the contacts furring up, so always make sure you spray a bit of wd-40 or someting down the switch slider shaft afterwards.
Posted on Oct 27, 2008
Just quit working one day, drill is just over a year old not used a whole lot, pull trigger and nothing happens
Are the batteries fresh? How about the switch? Is it in the right position? I can't believe the motor has died. Even a dead battery will spin it a little. Check that out and let me know what you find.
May 03, 2010 | Dewalt DC910KL Heavy-Duty 1/2" 28V Nano...
My Rigid 18v drill has lost power even after full charges. There also seems to be a dead spot when I pull the trigger. In other words, at a certain point when the trigger is pulled the drill shuts off so I...
the trigger mechanism is either worn or dirty, this wouldnt be a battery issue. the batteries in the pack depending on how old the drill is are probably nicad batteries. they will loose their pep after repeated cycleing over time. ive seen people replace the batteries in the packs if your handy with a soldering iron if not new packs are the answer, for the switch, if you dont want to dis assemble and clean, try blowing it out with air hose around the trigger area
Jan 31, 2010 | Drills
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Dec 05, 2009 | Milwaukee 2610-20 18V Cordless M18 High...
THE TRIGGER SWITCH IS STUCK
If it is over a year old considering replacing it, they are not that expensive. You will be getting hit for batteries etc in the next few months, and by the time you purchase them you can buy another unit and have spare batteries.
Good luck,
Gilshultz
Dec 03, 2009 | Campbell Hausfeld 19.2V 2 - Speed Cordless...
Kawasaki 19.2 cordless drill
I will go one further, they had a recall of their batteries which could have led to your problem back in 2007 and the chargers on some of them also. I would again call the number and give them the date codes from both and then try again at getting it replaced. Their are a lot of posts online for this to be a simple occurence, The battery could have shorted internally causing the switch to melt and there would be a potential for user injury also. Let me know if you find anything out and if you have there web address I would be interested.
Jun 01, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Mar 13, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Dec 13, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Makita 6337D cordless drill problem
It is possible that the batteries are no longer good. They may need to be changed. These batteries do reach a stage where they no longer hold charge.
On rare occasions I have seen the gear box jam or the motor bearings go defective.
Jerry G.
Apr 01, 2008 | Kitchen Appliances - Others
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
607 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
