Question about Fujitsu ScanSnap S1500 Instant PDF SheetFed Scanner (PA03586B005) Flatbed Scanner
Fujitsu scansnap light blinks but doesn't scan
3 Suggested Answers
dragon_sun25
  • 107 Answers
SOURCE: Will the Fujitsu ScanSnap FI-4110EOX2 scanner work with Vista
Vista is not listed as a supported os.
Posted on Dec 10, 2008
aroracaty2
  • 503 Answers
SOURCE: Hello, I have Fujitsu ScanSnap
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select "Scan Button Settings" from the Right-Click Menu.
2344c41.jpg Select the "Use Quick Menu" check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the "scan" button on the ScanSnap.
Click the "Scan to folder" icon in the quick menu when scanning is completed.
The "Scan to Folder" dialog box appears.
Check the scanned image in the "Scan to Folder" dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Oct 08, 2010
Won't scan light blinks 5 times
check to make sure the ScanSnap Manager is running.
Nov 04, 2013 | Fujitsu ScanSnap Manager
Scan snap won't work
This is a known problem with Fujitsu ScanSnaps. Some units experience the "blue button of death" meaning they no longer respond to waking the driver up when you press the blue button. Customer service is aware of the problem and if you are under warranty you should be able to get a new unit.
Mar 21, 2012 | Fujitsu ScanSnap S1500 Instant PDF...
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
My Scan Snap won't scan. The Scan light just blinks and nothing happens.
My Scansnap was being used through a USB powered hub.
This worked....Shutdown EVERYTHING and unplug computer from your powerstrip for 10 seconds (or just turn off your powerstrip for 10 seconds) It resets the BUS power. This solved why almost all of my USB devices stopped working or were behaving badly.
Jun 01, 2010 | Fujitsu ScanSnap Manager
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
Open Questions:
See all Fujitsu ScanSnap S1500 Instant PDF SheetFed Questions
Fujitsu ScanSnap S1500 Instant PDF SheetFed Scanner (PA03586B005) Flatbed Scanner Logo
1,584 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
