Question about Whirlpool Calypso GVM9959K Top Load Washer
Calypso wash motion washing machine FL code stuck
HI, The machine has worked fine for over a year. Now it has an FL code fashing on the display. There is some water left in the bottom. Will not reset with any buttons, have unplugged and replugged in multiple times, to no avail. HELP??!! Any ideas would be appreciated, thanks! M
  • Anonymous Feb 25, 2008
    FL Display will not stop
    The FL shows on the display.
    how do I reset?
    Problem Solver:
  • 12 Answers
Calypso washers have been known to be problematic. In fact, there is a class action suit out there which could be beneficial to you: http://www.calypsosettlement.com/ According to Whirlpool FL stands for Flood Condition. Here is their explanation of it: ----- FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. ----- Hope this helps.
Posted on Aug 08, 2006
    New Friend:
  • 163 Answers
Jesus crist and you post all that information just like that..waooooh
SOURCE:
Keeps getting fl error message
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
Jan 27, 2016 | Washing Machines
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
My calypso washer will not work, the flashing light says FL ? Can you help
The FL error code means:
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washing machine will not start... about 10 years old.. used to reset when i blew into the water level sensor - would show FL, then somehow rest itself.. not now it shows FL, can only get rid of the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%!#
Aug 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer GVW9959k stuck on FL
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL ERROR MESSAGE
Hi and welcome to FixYa,
Initially, "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Dec 04, 2008 | Kenmore 24902 Top Load Washer
Crosley Front Load Washing Machine
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
Feb 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer displays FL code Hi Where do I find the model number for my machine. It's a Kenmore Elite Calypso Motion Top Loader? I am getting an error code of FL and need to trouble shoot problem but, I have...
I GOT THIS OFF THE MANUAL, HOPE THIS HELPS.
"FL' (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the over fill switch is reset or power is discontinued to the
unit. Press STOP/CANCEL to clear the display. Shut off the
water faucets to the inlet hoses if water continues to flow.
Nov 08, 2007 | Washing Machines
Open Questions:
Whirlpool Calypso GVM9959K Top Load Washer Logo
506 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
