Question about Toshiba Satellite P105-S6064 Notebook
Screen half black
Laptop runs Windows XP. Will boot up but only left screen seems normal which displays icons. Right half is black.
    Master:
  • 388 Answers
Either the screen has gone or been damaged or check the screen cable isn't loose or replace this first its cheaper than the screen go to eBay type n the make and model of your lappy and screen cable
Posted on Feb 11, 2012
Asus x58l half black screen
Damaged screen. Replace it.
Mar 17, 2014 | ASUS Computers & Internet
My laptop screen is zoomed in which is making all my icons huge. It makes my Internet pages huge also. How can I zoom out so my screen is back to normal size?
use this if using windows vista/windows 7
Set the zoom level in Magnifier. This can display objects on the screen up to sixteen times larger than actual size. Follow these steps to choose the magnification level that you want.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Magnifier.
  2. In the Scale Factor list, select a level. The zoom level in the Magnifier window will change right away. Adjust the level until it's right for you.
use this if in windows xp
  • 1 Click the "Start" button in Windows.
  • 2 Select "Control Panel."
  • 3 Select "Appearance and Themes."
  • 4 Select "Change the Screen Resolution."
  • 5 Look at the left side of the "Display Properties" dialog window. About half way down the screen you will see a box labeled "Screen resolution." There is an adjustable slider in this box.
  • 6 Move the slider left or right, by holding down the left mouse button, and moving the mouse in the appropriate direction. Release the button when the slider is pointing to the resolution you desire.
  • 7 Click the "Apply" button at the bottom right of the window. The screen will go black for an instant, and then will switch to the new resoulution. You will also see a message pop up asking you to confirm the setting. If you are unsatisfied with the appearance, then click "no," and try another resolution. Otherwise, click "yes."
  • or try the accessibility mode
    1) press start goto control panel be sure use are in classic view
    2) select accessibilty options and select display tab and uncheck the enlarged icons option and apply and click on ok. this will reset all programs to a smaller view.
    ROB
    Nov 25, 2010 | Computers & Internet
    Computer starts then goes to black screen and system recovery wont work error code 257'
    The display drivers maybe corrupt.
    Boot the machine into safe mode. Right click on My Computer (XP) Computer (Vista) and select manage from the sub menu.
    When the window pops up select Device Manager.
    A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
    Restart the computer and let it boot in normal mode.
    If it boots in normal mode let it detect the Display and install the drivers for it.
    I would be a good idea to update the display drivers via the Dell Support website
    Regards.
    Sep 30, 2009 | Dell Computers & Internet
    Black Screen Dell 600 Laptop
    I would be a good idea to update the display drivers via the Dell support website.
    If it still won't display in normal mode please post back.
    Good luck.
    Sep 17, 2009 | Dell Inspiron 6000 Notebook
    Dual boot
    There's probably a problem with your display drivers in XP.
    Try booting in Safe Mode (F8 on startup). Now your display should work.
    If you boot in safe mode with networking, you can visit the graphics-card manufacturer's website and download the latest drivers. After installing these, try rebooting normally...
    Dec 11, 2008 | Dell Inspiron B130 Notebook
    Laptop display is split both horizontally and vertically in WinXP
    the last one i had with this prob had an ati radeon xpress 200m video card and it was defective had to replace it.
    Dec 05, 2008 | Toshiba Satellite M30 Notebook
    Dell 1200 Inspiron OS boot problem
    Two things you should try to resolve this issue: -
    • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
    • If this works there is no need to try the second option.
    OR
    • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
    • Select the option to Boot to safe mode.
    • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
    • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
    • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
    • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
    • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
    Nov 15, 2008 | Dell Inspiron 1200 Notebook
    Enlarged icons and text
    The following should get you back to normal:
    1. Click the "Start" button
    2. Click "Control Panel"
    3. Click "Display"
    4. Click the "Settings" tab on the top
    5. Near the bottom is a box that says "Screen Resolution" , to make the stuff on the screen smaller , slide the bar toward the right and hit apply. You may need to slide it over a couple of times to make the display look correct on your screen.
    That should fix you right up!
    Sep 30, 2008 | HP Compaq Presario V6000T Notebook
    Toshiba Satellite P105-S6064 Notebook Logo
    74 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
