I have a toshiba satellite L655 motherboard #A000075480 what do I need for fan heatsink ,fan
I purchased a toshiba motherboard #A000075480 but no heatsink ,fan , cpu I need to know what I need
  • 1 more comment
  • Norman Newell
    Norman Newell Feb 12, 2012
    I knowthere on ebay but there alot of different ones I need the one to fit this motherboard A000075480
    Thanks
  • David Bottomley Feb 12, 2012
    Toshiba L655 Intel MotherBoard Complete w/ P6100 CPU A000075480 put this in the search on ebay
    P6100 CPU is what you need
    Master:
  • 388 Answers
Not sure what you mean do you need a heat sink or a fan either one can be found on eay
Posted on Feb 11, 2012
Testimonial: "Hey thanks a million I have been trying to figure this o0ut for 4 days and just needed to post it and wait for you,thanks again Norm"
jilpeshpatel
  • 259 Answers
SOURCE: Need service manual for Toshiba Satellite 3000-400(PS300E)
Dear http://www.laptoprepair101.com/laptop/category/laptop-service-manual/
pls open this link and select your model number and downlod the service manul for tohshiba
Posted on Apr 07, 2009
  • 211 Answers
SOURCE: need to know how to dismantle Toshiba Satellite
Here is Toshiba Satellite P105 (which is the same as P100) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, ...
Posted on Sep 02, 2009
  • 41 Answers
SOURCE: I want to change the CPU fan in my Toshiba
I found an awesome site
I found the service manual for the Toshiba Satellite M40X in PDF format
You want chapter 4 replacing the cooling module.
http://tim.id.au/laptops/toshiba/satellite%20m40%20tecra%20a4%20dynabook%20vx4.pdf
Posted on Nov 10, 2009
NzyComPro
  • 5 Answers
SOURCE: Toshiba Satellite Pro L10 - Fan does not work!
Take out fan from CPU. test it using external power Batt 5v. if its works, its could be your motherboard going to spoilt soon..
Posted on Nov 19, 2009
  • 4 Answers
SOURCE: I'd like to connect my
If you have a flat panel TV (LCD or Plasma) then you can connect your laptop using an HDMI cable. Your laptop should have an HDMI port on the side. Buy the cheapest HDMI cable that is long enough (six feet ought to do it). Don't pay more for a "gold" cable, it's a rip-off. With HDMI, video and audio are carried in the same cable. Your laptop should automatically sense the TV set and auto-adjust itself.
If you have an older-style CRT TV then things will get more difficult. Then you'll need a VGA to composite or VGA to S-video. With a converter, you need separate cables for video and audio. Here's one that will work:
http://www.chronos.com.tw/_products_0616/tv/PC%20to%20TV/Pc%20to%20Tv.htm
Using the converter, you'll have to tell your laptop that you are connecting to an external device.
Posted on Oct 12, 2010
Sound not working
You need to set the the Default audio device to the speakers in the Control panel and make sure the sound is not "muted" (turned off)
Feb 18, 2013 | iTEKIRO Laptop AC Power Adapter Notebook...
L655 Satellite won't start up.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Dec 17, 2012 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba satellite l655 turns off while plugged in
Check the cooling fan and heatsink, remove the heatsink and fan, use a can of compressed air to clean out the ports and fins, then check the thermal paste between the processor and heatsink, remove if hard with rubbing alcohol and a paper towel, apply fresh compound and assemble.
Jul 09, 2012 | Toshiba Satellite Computers & Internet
How to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Apr 15, 2012 | Toshiba Satellite L655-S5160 Laptop PC...
Satellite L655D-S5093 keyboard removal
This is the User's Manual for the L655-S5098 laptop:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2759985&rpn=PSK2CU&modelFilter=L655-S5098&selCategory=2756709&selFamily=1073768663
Predictably, its useless when performing maintenance such as keyboard replacement, but page 82 indicates that this laptop supports "most USB-compatible [external] keyboards", so, while the chicklet keyboard is down, you can boot and use the system with a workaround USB keyboard.
I could not find an L655-S5093 laptop model on the Toshiba support web site, which is found at http://www.pcsupport.toshiba.com
The closest I could locate for you are these two How-to Guides:
Here's a teardown of the Toshiba L645/L645D laptops:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/remove-laptop-motherboard-1.htm
Here's a teardown of the Toshiba L675D laptop:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/dismantle-laptop-1.htm
Nov 27, 2011 | Toshiba Computers & Internet
Sir, iwanted to know weather i could add an graphics card to my kaptop toshiba satellite L655-S5112?
Sorry for the delay. Unfortunatly, you can not add a graphics card to your laptop without having to redo the video port on the motherboard itself.
C2Solutions
Oct 23, 2011 | Toshiba Satellite L655-S5112 Notebook
I have a toshiba satellite L655-171 system unit and i can't find the bluetooth.Is it possible not to have this kind of setting?
Hi darknuage...
You do not have bluetooth on this Toshiba Satellite L655-171 according to the spec sheet I found at this website...
But you can buy a bluetooth dongle and have bluetooth on this computer.
Please take time to rate me
http://laptops-specs.blogspot.com/2010/06/toshiba-satellite-l655-s5071.html
Bluetooth Dongle
http://www.dealextreme.com/p/super-mini-bluetooth-2-0-adapter-dongle-vista-compatible-11866
Aug 12, 2011 | Toshiba Satellite L655-S5101 Laptop
I HAVE A TOSHIBA SATELLITE A2215- S7422..I CHANGED THE FAN ON CAUSE IT WASN'T RUNNING CORRECTLY AND IT STARTED UP AND WHEN I CHANGED THE FAN IT TURNED ON THEN SHUT OFF THEN I GOT IT DIGNOSED AND THEY SAID...
Hi:
The charging light can come on, even if the motherboard is bad.
I would suspect that possibly something was not assembled properly when you changed the fan. One thing to try is to take the laptop back apart, and remvove the heatsink/ fan assembly again, and make sure your CPU is properly installed, and that it is locked in place. Re apply heatsink compound and hope for improvement
Nov 30, 2009 | Toshiba Satellite A215-S7422 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
