Question about Sony Computers & Internet
Sony vaio laptop screen shows vertical lines upon booting then proceeds to windows loading with semi transparent vertical bars on background. Upon logging in, screen displays everything in a large scale and very pixelated with abnormal color schemes. Windows functions normally just the projected display.
    Master:
  • 388 Answers
The screen inverter is on its way out simple to replace unscrew the rim on the outside of the screen pull it off gently at the bottom there is a stip with wire going into it at each end disconnect it remove it do the reverse to put it in i suggest ebay for spares
Posted on Feb 11, 2012
How do i reboot my laptop
Restore to factory settings
Restoring your Sony VAIO computer to its original factory settings is a great way to remove old programs and files that are buried within your computer that you no longer need, or to get rid of a virus that you just can't seem to shake.
This process will allow you to start anew with your computer, and can potentially save you from simply throwing the computer away because you don't think it can handle the workload anymore and spending money on a new machine.
Unplug any cables connected to your Sony VAIO machine with the exception of the power cord and monitor.
Click "Start" in the lower left corner of your screen.
Click "Control Panel."
Click "Performance and Maintenance."
Scroll down to the bottom of the Performance and Maintenance screen and click "VAIO" recovery wizard. The VAIO Recovery Wizard dialogue box will appear.
Click "Next."
Select "Proceed with System Recovery" and click "Next."
Select "C Drive Recovery" and click "Next."
Click "Next" to confirm that you want to proceed with the C Drive Recovery.
Click "Finish" to restart your Sony VAIO machine and initiate the recovery procedure.
Upon restarting your computer, the Sony VAIO Recovery Wizard will prepare your hard drive for recovery and then restart your computer again.
The necessary files will be copied to your computer and your hard drive will be recovered.
Click "Finish" when a screen appears telling you that your recovery process is complete.
Your computer will restart.
Click "Next" when you arrive at the Windows setup screen.
Follow the on-screen instructions to setup your version of Windows.
When you have finished setting up Windows, click "Finish."
Upon restart, the Sony VAIO Recovery Wizard will install necessary files on your computer.
Your computer will restart automatically when these files are installed and your Sony VAIO will be restored to its original factory settings.
Hope this helps
Oct 14, 2012 | Sony VIAO Laptops (Laptop NOT Included)...
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
When i press the power button the VAIO logo shows then a Intel logo after that there is just a blank screen and windows wont load. what should i do?
Upon starting go to bios settings, click "F2" to access the bios, go to to exit, choose "Default Maximum setting", save upon exit....restart.
Hope that helps you out, msg. me is there are still problems.
Thanks for asking FixYa!
Aug 15, 2011 | Sony VAIO VGC-RA840G PC Desktop
My sony vaio always loads up an application called hidden form I see in windows task manager. various help lines say it comes from vaio marketing tools but I cannot find that on my program list. I am...
Any application loaded into the memory takes its toll depending upon its size and nature. You can use CCLEANER software/utility. Its FREE, small size, easy to use and completely safe. Click here to download CCleaner. Install CCleaner, Click 'TOOLS' and 'STARTUP' and look for the application and if found here, disable it. As you have not mentioned the name of the application I can not say much about it. Before deleting/ disabling the application, search the internet to check if the application is safe to remove, its function may be required.
Make a backup of the registry before proceed. However, you may proceed without registry back up, if you like.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 19, 2011 | Computers & Internet
Upon start-up my Dell Inspiron 1545 laptop will not proceed past the loading microsoft screen and brings me only to the wallpaper background....no icons, task bars, etc. No response with any of the...
You might try loading in the safe mode. To do that, you tap the F8 key when powering on until a list of options show up select safe mode. and follow promotes on the screen. If you get the full desktop, you will want to go to my computer, select c: drive and properties. You should see a listing there for error correcting. It may be called something else, on your system but it's purpose is to correct errors on your hard drive. click on that and follow the on screen instructions. Good Luck
Apr 01, 2011 | Dell Inspiron 1545 Notebook
Upon boot up, my screen/cursor freezes in safe mode, it comes up OK.
Welcome to Fixyah,
When your laptop boot up in safe mode meaning that there will be something wrong with your system, Finished bootingup till the window open in s afe mode and from there try to check what is the last software that you trying to load then try to uninstall it or try to check the settings.
Aug 10, 2010 | Sony VAIO VGN-Z550N/B Laptop
After installing an automatic update, upon re-starting, my computer will load the windows xp welcome screen, the blue bar, under the windows xp icon, scrolls as if the computer is booting up. The screen...
Sounds like the HAL.DLL problem that I have with my Aspire One.
Try booting off a genuine Windows XP disc and choosing the 'recovery console' option. At the command line, type 'CHKDSK C:' and press Enter. If you're lucky, that will do the trick.
Feb 07, 2010 | Acer Aspire 5050-3242 Notebook
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
Computer startup
can you try right clicking the desktop and click view on the pop up menu, then under view click show desktop icons.
Apr 17, 2009 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
