Question about Mitsubishi WD-65733 65" HDTV
Code 38 My tv is under warranty, what does Mitsubishi need to replace if I am showing code 38? They have replaced the lamp and no change.
I was told after a lot of research that there is a temp sensor for the bulb in the TV that goes bad or gets to hot due to a foam screen that's intention is to prevent dust from entering the tv getting clogged with dust.
  1. Unplug the tv
  2. locate the cooling air foam filter housing. it's in the the center of the back of the tv right in the middle of the audio video connections.
  3. depress the little tab for the filter retainer which looks just like the tab you depress to open the battery cover on your remote.
  4. remove the foam filter and clean by beating it against something or wash it and dry it thoroughly and reinstall.
  5. Then give it a shot
  6. if this doesn't work it's probably the thermal sensor for the bulb. *Note: Mitsubishi know's about this problem and will pay for a Mitsubishi factory authorized service Tech to come out and repair this problem free of charge.
  7. to find a Service center in your area call 1-800-332-2119 follow prompts just input your zip code when prompted and it will give you the service centers closest to you.
Posted on Nov 11, 2008
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
My Mitsubishi WD-73734 TV will intermittently just shut down- no picture, no sound, the set just turns off. When I check the TV for an "error code," I am able to identify error code # 38. What...
38 Lamp temperature abnormally high. Poor Air Circulation - found in service guide at - http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf
Dec 17, 2010 | Mitsubishi WD-73734 73" Television
Picture suddenly dimmed and i have not had the t.v. for 7 months with limited use. I checked all the settings and nothing seems to brighten the picture. One instant the the picture was great. I come home...
It could be the lamp, they have an approximate 1 year life depending on conditions. If you bought the TV new, it has a 1 year warranty and labor you might want to contact warranty support. They will send you a new lamp.
To Receive a Replacement Lamp Under Warranty
Call (800) 553-7278. Please have model number, serial number, and TV purchase date available.
Important: All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect
verification.
Appendix C of the manual describes how to change the lamp. Handle with care (avoid fingerprints on the new lamp). Make sure the TV is off for at least an hour before starting.
I hope this helps.
Jun 28, 2010 | Mitsubishi WD-65731 65" HDTV
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp worked for a few days and now it wont power up, now when you turn it on the light blinks green and then the yellow lamp light comes on and no sound or picture.
when the set shuts down check to see what the error code is, press the input and menu buttons at the same time, hold them down for 10 seconds, the green light should blink a two digit code, if this is 38 then you have a thermal sensor problem and need to call Mitsubishi for extended warranty repair.
Sep 08, 2009 | Mitsubishi WD-65732 65" Projection HDTV
When I turn on the TV, nothing comes on. No pictures or sound. Red light comes on where it says lamp. Do I need to replace the lamp. Please kinldy advise . Ty
Yes. You need to replace the lamp. Mine did this when my lamp burned out.
You can try pressing <menu> and <device> at the same time, and you'll get a code flashed out to you (tens digit followed by unit digit). You'll likely see one of the following codes:
  • 34 Lamp abnormality
  • 36 Lamp Ballast or exhaust fan failed.
  • 38 Lamp temperature too high
  • 42 Lamp Fan Failed
But the user's manual and the repair manual both say that a red lamp light means your lamp isn't working (most likely it needs to be replaced).
May 10, 2009 | Mitsubishi WD62627 62" HDTV
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62526 - Error/repair code
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Oct 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd 57731
Thats a lamp abnormality, sound like the two 3300uf caps on the PWB PCB need replacing
Jun 29, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-65733 65" HDTV Logo
203 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
