Help My laptop wont start up?
HI, When I plug the computer into the power cord the Wirelwss ,power and hard drive lights and 2 light jabove the keyboard light up but nothing happens with computer.
    Master:
  • 388 Answers
Sounds like you Ram has blown (RANDOM ACCESS MEMORY) SIMPLE TO REPLACE'unplug from the mains turn the laptop over remove the battery you will see a few panels remove then to expose the RAM which is a chip about 3cm on and 1.5 wide two metal clips on the side pull them apart the chip will pop out ther may be two remove one and try to start the computer if it works then the one you removed is faulty on the chip it will be marked ( PC-333-5400) OR SOMETHING LIKE THAT this is the part you need to replace put the code in eBay order pop it in job done
Posted on Feb 11, 2012
2 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: Took laptop keyboard and hard
Welcome to Fixya
Try to drain the remaining static energy of the board. Take out the battery and unplug the power adapter from yor computer. Press and hold the power button for 15 secs. Put everything back in and power on the computer.
Thank you for using Fixya!
Posted on Jan 18, 2011
My medion desktop model pc mt 14 wont switch on from the mains
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Pressand Hold the power button for 30 seconds. After 30 seconds plug the powercord back in and hit the power button to see if it boots.
Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Maybeyour power supply is bad. Sometimes there is enough power to make thepower light come on but not enough power to make the fan turn on or harddrive spin.
May 27, 2012 | Medion Computers & Internet
Hi my Samsung R730 wont power up after shutting down when battery was low have tried pluging it in to mains and pressing power button but nothing works
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 13, 2012 | Computers & Internet
Compaq presario v6101uswont boot not even start up screen
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
My laptop shuts off after i turn it on.why
Does your laptop even begin the boot process where it displays stuff on the screen? Do you hear fans running, disk drives running, see lights, hear the cd drive click once and notice a light that comes on the cd drive door briefly when you press the power button? If not you computer either has a bad power cord, a bad dc power jack where the power cord plugs in, a bad mother board or static build up. 1) lets eliminate static buildup by removing the power cord and the battery then press and hold the power button for 30 seconds. Then replace the power cord but not the battery and hit the power button. If it boots up you had static build up. 2) Take an ink pen and put in in the slot where the power cord plugs into the laptop, if it wiggles loosely then your dc power jack which is soldered onto the motherboard needs to be replaced. 3) If the power jack is tight and when you plug in the power cord if you don't see any lights or hear a fan, disc, cd drive, then you can almost bet your power cord is bad. 4) If the power cord is ok then you have a mother board issue. Normally motherboards will give some beeps or constantly blinking lights when you plug in the power cord and try to boot up. These beeps or blinking lights will tell the technician what is wrong with your computer.
Mar 19, 2012 | Acer Aspire One Netbook 8.9" Notebook
Gateway MT3421 Laptop start-up Issues
Start by removing the battery completely, and plugging the power cord into the wall socket. If the power indicator light comes on at the converter on the cord, your power cord is fine. Then plug the power cord into the computer. If the computer starts up you know the power cord connection on the computer is not the problem. Now witrh the power cord plugged in install the battery if the needs charge light comes on you probably do need a new battery as the cells often do go dead after a period of time and wont hold a charge, this will cause the LCD screen to go black or gray, but NOT BLUE. Borrow a friends monitor and plug it into your computer as an external monitor and press the function key to toggle to external monitor. Now try to restart, if screen shows activity you can atleast check out your computer. You may want to test your connections andf then itry placing your hard drive into another similar computer and see if the same thing happens, if it does your hard drive may have a failure. You can transfer all the info from your hard drive to an external drive through a patch cable available online at circuit city for between $7-25. The two that are most useful are the CTG Laptop to IDE Hard drive adapter item C184-17705 and the Ultras USB 2.0 to IDE/SATA cable adapter item UL740112 depending on what type of hard drive connections you have. Once you transfer your information to an external you can try to restore your computer using the original system restore disk that came with the computer. Set to boot from disk and away you go... If this does not work you may have a bad hard drive or possibly the mother board. If the mother board is bad you may want to just keep the computer for spare parts as it might not be worth the cost of repairs. If it is the hard drive you can get good quality Hitachi Harddrives reasonable (for less than $90 for upto 600 GIGS on line again at circuit city without any shipping cost and will have it within a couple of days.
Hope this helps.
Feb 08, 2010 | Gateway MT3422 RTL Notebook
Hi Hoping some one can help me I have an acer
U ARE HAVING PROBLEM WITH UR POWER CORD OR YOUR BATTERY
Jul 15, 2009 | Acer Aspire 4520-5582 Notebook
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
My Laptop wont power on
Hi
Since your computer is not starting up at all its probably not a problem in the hard drive (where the files are stored) It is most likely a problem in the motherboard. Try removing the battery and ac then plug in the ac and try starting up, is the ac working? do you have a power light on the laptop that turns on when you plug in the ac adapter?\
If you don\t have a power light you need to get the ac adapter tested if the adapter is fine then most likely the issue is in the motherboard.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you,
Ekse
Aug 02, 2008 | HP Pavilion dv6227cl Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
